EZ-RIDER's Avatar
Thumbs up RapidBike Box for R1100S
Hi Gang;
Just installed the New RapidBike Box on the R1150S !
Went for test ride today, bike ran great, down loading
the map from Rapid bike.com was a breeze!
Had the first Power Commander, No more hard
starting issues etc. Better product all the way around
Thanks Robert Foster your the Man
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 08-18-2007, 01:51 PM
No try, do or not do
shreddr's Avatar
EZ if I recall correctly you were advocating we all hold out out because "something better was in the works" so you went and bought a Rapid Bike? What gives?
2017 R1200GSW Rallye Shreddr Signature Model
Old 08-18-2007, 05:35 PM
EZ-RIDER's Avatar
I have been working with Robert Foster and Rapidbike
It's a tuners dream ! Like I said I had the Power
Commander on my bike, Removed it and wouldn't go Back!!
Two Thumbs Up
Old 08-18-2007, 05:58 PM
shreddr's Avatar
The Rapid Bike has been available for a while.
Old 08-18-2007, 06:03 PM
EZ-RIDER's Avatar
Not for the R1100S
Old 08-18-2007, 06:05 PM
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
Originally Posted by EZ-RIDER View Post
Not for the R1100S
It's been listed on Rapid Bike Italy's site for over a year and a half I believe, just no one wanted to be the first stateside. The cold start issue should be a plus and being able to set what throttle positions to map should be a plus, but peak performance wise I'd like to see a dyno back to back with your old PC and new rapid bike. Really need to have that Rapid bike module custom mapped for your 1150 setup, I'd bet there is some left on the table. We will be doing a RapidBike III module custom mapped from scratch (the right way to do it) in the next couple weeks, I'm sure we could get ya tweaked that much better then a standardized map. Too bad the Rapid Bike I for the R1100S is only capable of fuel/injection and not ignition/RPM as the RBIII is for the R12's
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
Old 08-18-2007, 10:05 PM
EZ-RIDER's Avatar
I have had the bike on the dyno with the power commander many times, I will have it on the dyno with the Rapidbike box soon! Will post both dyno Map charts, Power Commander vs Rapid bike Box.
I had one of the first Power Commanders for the R1100S it was a modified Triumph
power commander from Chris at San Jose BMW ! It worked OK but I Think this is
a better system.
Old 08-19-2007, 07:44 AM
Regnat populus
boxercup's Avatar
BMW Roundel Ok Now....
Greetings E-Z,
Thanks for your report.
The R1100S RapidBike #1 has been available for many years and has proven to be a well respected "Tuners Tool". We have been distributing them for it's parent company DimSport for a few years now.
To avoid any misunderstanding with E-Z's R1150S......we did not just send a shipping R1100S RapidBike #1 Module....He has special requirements with the many mods on his bike.
E-Z has a special RB#1 Module (Specifically Coded Firmware)and a custom made wire harness. This was never available until we created it two weeks ago to suit his requirements. This is not a standardized map whatsoever.
Thus the New in his report!
BTW, give E-Z some credit he installed it in a garage @104 degrees..... I even called him to see if he was still alive....and reached his voice mail.....Glad you are still flowing E-Z. Stay Cool
We took the challange and it was a success.
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 08-19-2007, 08:47 AM
Cyclone Jack
hawkeyejohn14's Avatar
Time to put her back on the Dyno.. I gotta check out your bike next year when I drop back home to see family and friends, oh and to ride those NGA mountain roads...
jc
2004 R1100SA Pacific Blue
Old 08-19-2007, 09:34 AM
a better system.
Same dyno and operator for the before and after? I'd like to see you run on the dyno we use since you're in our neck of the woods now because my numbers aren't that far off of yours with stock 1100cc pistons, stock head and BBPower chip being the only difference. Would be nice to see the incremental gain for your high compression 1150's. If you do try to dyno locally we have a good recommendation for you as the others in the area are not anywhere near as BMW savvy. Either way we always make it a priority to dyno any new mods asap because the exhaust gas analyzer is a very good level of assurance that you're butt is properly calibrated.
Bobby
Old 08-19-2007, 04:29 PM
Irregular user ...
Crunch's Avatar
EZ rider ... I take it from your post that you acquired your 1150S from SJBMW and then started modifying from there? I have one of the few 1150S from SJBMW, with that original Power commander and the Remus exhaust. Good setup, but you really have me thinking about cams and port/polish!
Old 08-20-2007, 05:50 PM
EZ-RIDER's Avatar
No I built the bike myself
Old 08-21-2007, 01:26 PM
shreddr's Avatar
EZ, what made you go for the new cylinders rather than just get the HC pistons? The difference is only 45cc. Do you feel the cost warranted the benefit? I am considering the same thing myself, but might just do the pistons.
Old 09-03-2007, 04:42 AM
EZ-RIDER's Avatar
Hey;
I went with the 1150 cylinders and 12:1 pistons, It gave me 12 more hp in the mid range and few more up top! If you asked me if it was worth it !
yes and would I do it again the answer is yes increased the fun factor by 50%
Old 09-03-2007, 07:46 AM
shreddr's Avatar
EZ, can you give a summary of all engines mods you have made and the impact on perfromance. I know you went with a modified Rapid Bike, did you go to a tuning center? If not where did the map come from. I am considering a Rapid Bike as well because I may want to do some more mods to my engine.
Old 09-03-2007, 09:23 AM
EZ-RIDER's Avatar
1150cc cylinders machined to fit the R1100S engine block 12:1 pistons race cams lightened valve train , bigger valves intake and exhaust, Ported and polished heads Lennies In-duct San Jose power filter! RapidBike Box
HID lights hi and low beam, Racing rear sets Laser Boxercup Exhaust!!
Old 09-05-2007, 06:31 PM
EZ-RIDER's Avatar
Also the bike now has over 15,000 miles with the pistons and cylinders
Old 09-05-2007, 06:36 PM
