blown headlight. Replacement doesn't light
Last night I was firing up the bike when I noticed a strange behavior with the headlight. As it turned out, it had blown. I pulled the bulb and replaced it with a working (not brand new but known good) bulb. This did not work. I figured that it took out the fuse too. I checked the manual for the list of fuses, and oddly enough, there appears to be no listing for one. Doing a search on the forum yield the info that there isn't one. I am now stumped. I guess I am going to check if there is a voltage across the circuit. Maybe the wiring got damages somehow. There isn't any overt sign of a problem.
Any tips are appreciated. Thanks
04 R1100SA (Pacific Blue metalic) 99 R1100SA (black) -- Totalled |
Oh Nevermind. You know that part where I said known good bulb.... Sigh. It must have gotten busted somewhere along the line. Voltage Check. Bulb, no check..
fuse location
as far as the fuse is concerned, its a 7.5a mini spade style in the little fuse block under the left front hand deflector, sorry no picture...
claus IBA, 03r1100s "Lili Marlene", 06boxster "black sheep", 06f650dakar, Auf Adlers Fluegeln getragen... |
