adjusting preload on rear Ohlins
Guys, I need some help. I decreased the rear preload on my 12S to try and give me some extra sag due to my short inseam. I don't care for the handling now and want to increase preload to where it was. But, when I turn the adjusting nut, which seems to be made of some kind of plastic/fiber (?), after about a quarter the nut "jumps" the thread back to where it was. WTF?
What's the trick here? Do I need to unload the shock, remove it, use a spring compressor, or what?? I've never seen this happen on any of the many shocks I've adjusted on my bikes. Help!!
Mal Glanz Ft. Lauderdale, FL '12 ZX-14R '09 CBR1000RR (w/pegs & bars, now my touring bike) '10 S1000RR & '07 R1200S (gone, but loved 'em) |
unsafe at any speed
you are not alone. The nut is plastic.
here is a thread that discusses the issue. Plastic Adjuster Ring on R12S Ohlins Hope this helps. .
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 01-27-2008 at 12:11 PM.. |
unsafe at any speed
I wish I did... i have an 1100 not a 1200.... I remember there was a part number for the replacement ring in that thread....
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
unsafe at any speed
Your best option would be to have Pro Pilot install one of those hydraulic adjusters like Steve Carlton had done.... Here is a great thread he posted about that mod.
Upgrading the R1200S Ohlins
Uh....who me?
It's still under warranty isn't it? Take it to the dealer and maybe they have a metal replacement instead of the plastic one.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
However, I was able to resolve the problem. I brought the bike to the dealer because I don't have anything at home to lock the front tire down so I could safely lift the rear end. After we raised the rear of the bike to unload the shock, we were able to increase the preload. Of course, it would have been nice if the CD instructed you to do that, but I couldn't find it. The Ducati 1098S guys are gonna be looking at the same issue.
I'm thinking that someone needs to fabricate an external spring compressor to take the load off the plastic ring nut so that it can be turned under a no-load situation. That woud take the stress off the plastic ring nut.
Bubba, go ahead and turn us out some. Titamium would be great, but we'll settle for aluminum (or as the English say, al-U-miniem).
You could patent it and call it the Bubba Nut. I'll take one as soon as you run a batch off. |
A batch off of Bubba nuts??? No thanks...
Orange '08 KTM 990 Adventure for fun in the rough stuff Patientlty awaiting an R-bike sport tourer devoid of servos and EWS |
You guys are tough on Bubbas
Bubba - you going to join us in the BMW stands for the Daytona 200?
Working on a kitchen pass. Is there somewhere to camp?
Yes, there have been a couple threads on this.
No real need to go all the way to an HPA. Just get a metal ring. Otoh, if you don't need to adjust again, you can just live with what you have at no cost. And yes, the 1098S suffers the same. That was the first time I ran into it. The frame is tighter in that app, so it's a worse problem still. Very annoying issue.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Edministrator
I wonder if you could get BMW to replace the ring under warranty, if you could purchase the pre-loader yourself and have it "upgraded" from a metal ring to the pre-loader before the shock is re-installed on the bike?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
R1200s mmmm!
Good idea how much is the hyraulic preload adjuster? is there a part number that fits R1200s rear shock? I haven't adjusted mine yet but warranty runs out in May and was goan drop rear a bit, so best do it now and see I guess!!
Thanks Lee ![]() R1200s Red/silver, ABS, Ohlins, Sports wheels, heated grips. K1200r - R.I.P. |
Edministrator
Here's the menu Pro Pilot came up with after doing my shocks. You'd have to ask Jim about parts prices, as these include labor:
R1200s mmmm!
I dont see pic?
I believe you use the two jam nuts that are located just above the lower shock mounting point to adjust shock length... aka ride height? That way you don't have to compromise preload for seat height.
2007 R1200s 2002 SV650s (sold) 1994 R1100rs (sold) |
That is true, if there's some range left there. If not, then preload is the next best option.
