R1200s mmmm!
R1200s Dry clutch?
How many miles do you get out of one? I have 5000 miles on mine done by previous owner. Now i do a lot of town miles thru rush hour traffic and try not to slip clutch like i do a lot on a normal wet clutch!
I never had a problem with Ducatis dry clutch wearing out fast in town or anything but does the bmw single plate wear faster?
I only ask i saw on the dvd repair rom how hard it is to get at the clutch, looks like a split the engine in 2 job!!
Lee
R1200s Red/silver, ABS, Ohlins, Sports wheels, heated grips. K1200r - R.I.P.
Old 01-29-2008, 11:42 PM
Stampertje_35's Avatar
If you're not so hard on the clutch somewere between 75.000/100.000 miles, so you can drive for a while
Jack
R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm
R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike
All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74
Old 01-30-2008, 01:14 AM
R1200s mmmm!
Wow must be pretty hard wearing then! I would think its always best to let clutch out fully as soon as possible and not slip it, same as you would do in a manual car to avoid burning the plates away! Everyone rides different to i guess in how they use clutch!
Lee
Old 01-30-2008, 01:57 AM
It's almost the same clutch as a R1100xx or R1150xx, ( the same mechanics as used in cars)
ask hjr1100s, his R1100S had 135.000km (about 85.000 miles) on it without any big problems
Jack
Old 01-30-2008, 02:49 AM
Assuming you don't do dumb things (e.g., using the clutch to hold the bike on an incline) I doubt stop-and-go driving is likely to cause undue wear as engine speeds are so low. The problem with BMW clutches is that they overheat easily and thus don't tolerate abuse very well. The wet clutches in Japanese bikes have a method to carry away the excess heat of high-speed slipping that our bikes don't.
A couple of smokey burnouts on a BMW dry clutch and you've probably caused more wear/tear than several years of commuting. If you can smell the clutch roasting, be ready to open your wallet.
If you don't abuse the clutch and your technique is good, I think you can almost assume life will be indefinite. With the triple whammy of BMW unreliability with respect to spline issues, rear seal leakage, and tranny problems, routine clutch wear is unlikely to be the reason you dive into this area.
- Mark
Old 01-30-2008, 09:38 AM
Uh....who me?
Bob Hancock's Avatar
Originally Posted by markjenn View Post
If you don't abuse the clutch and your technique is good, I think you can almost assume life will be indefinite. With the triple whammy of BMW unreliability with respect to spline issues, rear seal leakage, and tranny problems, routine clutch wear is unlikely to be the reason you dive into this area.- Mark
+1. I think this about sums it up.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 01-30-2008, 10:04 AM
roger albert's Avatar
+2.
Mostly end up replacing clutches because the splines or and adjacent seal went, and damaged/contaminated the clutch, or just because you're "already in there" for a less severe version of either of the aforementioned. It's a happy oilhead owner indeed, who gets to replace a clutch solely because the friction material wore out (assuming no smokey burnouts - as Mark said, they don't handle that well at all)
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-30-2008, 10:55 AM
Riding the Mad Donkey
hjr1100s's Avatar
Is true.... but I do notice that on the 12S I work the clutch more then on the 11S. The 11S has a lot smoother engine, especially at low revs, low speeds, I work the clutch to get me through traffic or tight corners in a smooth way (bit like riding a Ducati). I guess a RapidBike tune up would do good ...
HJ
Old 01-30-2008, 11:02 AM
R1200s mmmm!
I always try and let clutch out fully all time as soon as possible so should be ok, but then dont know what previous owners did for 5000 miles lol!!!!
Lee
Old 01-30-2008, 11:39 AM
