Anything from Foster on the "Modulator"
Has anyone heard anything on the "Modulator" that Robert said would be out the middle of this month?
Old 02-26-2008, 12:24 PM
Regnat populus
boxercup's Avatar
BMW Roundel Modulator/Microprocessor
Greetings Frank,
Yes they are finally on their way from Italy.
This is a good Plug n Play solution to the fueling gaps on stock bikes thru modified ones. (Air Filter and Full exhaust systems)
Not nearly as precise as the RapidBike #3 but a good solution and price point combined with the lack of lean burn hazards and no dyno time necessary.
More later.
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 02-27-2008, 03:02 AM
How different is it from the O2 sensor unit offered by Evoluzione Cyclesport?
Old 02-27-2008, 04:41 AM
that looks like this
Old 02-27-2008, 04:43 AM
No try, do or not do
shreddr's Avatar
that unit replaces the O2 sensor, the one Foster showed a picture of became part of the fuel injector signal.
2017 R1200GSW Rallye Shreddr Signature Model
Old 02-27-2008, 04:09 PM
Regnat populus
boxercup's Avatar
BMW Roundel Hmmm...
Greetings Volo,
Good Question.
I respect Ken Zeller's work. He is a fellow tuner and he creates some nice stuff.
Our Microprocessor uses the o2 sensors and constantly monitors the lambda signal and reports to the ECU the necessary signal to modify the fuel and ignition mapping based on load and RPM. Rather unique in its design as the circuitry is active and it is plug n play. No dyno necessary.
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 02-27-2008, 04:16 PM
Snark and Soda
Steve Carlton's Avatar
So, who's going to be the master beta tester? If there was a money-back satisfaction guarantee, I'd be happy to try one out. But I probably won't have good weather here until April or May.
Robert, do you think much will show up on a dyno, or will it be more in driveability?
Two EVs and a BRZ
Old 02-27-2008, 04:42 PM
shreddr's Avatar
master beta huh? with all those women around that you've been posting pictures of?
Old 02-27-2008, 05:20 PM
Uh....who me?
Bob Hancock's Avatar
Robert I am definitely almost starting to think about putting one of these into my contingency financial plan maybe but have the same question Steve has. So....huh?
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 02-27-2008, 05:41 PM
I will, I will. I'm gonna kinda miss the popping on decel which gets a lot of attention, but have been holding off until this unit becomes available before getting an air filter. Drivability would be reason enough for me. Extra HP is gravy. Robert please tell me you're accepting orders-
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 02-28-2008, 02:26 PM
Snark and Soda
Robert- I'd like to try out this module if you will provide a money-back guarantee. In addition, I'll have the bike dyno-tested and post the results before and after, showing results at 50%, 75%, and full throttle as an indicator of driveability. I'll try and get this done ASAP, weather-permitting. What do you say?
Two EVs and a BRZ
Old 02-28-2008, 02:29 PM
shreddr's Avatar
uh oh....
Old 02-28-2008, 03:41 PM
shreddr's Avatar
someone correct where my logic is faulty..the O2 sensor monitors what is coming out of the exhaust and feeds back a signal to the ECU which in combination with the throttle butterfly position decides what the fuel injector is gonna do. I don't recall there being any feedback signal from the injectors to the ECU. If this is correct, then the O2 sensor plug and play unit, would more than likely send an ultra lean signal to the ECU which in turn would send a richer signal to the injectors. The only thing the fuel injector module could possibly do is modify the incoming signal to make it fatter. It would have to be a straight algorithim. Seems like the O2 unit would be the way to go, that or one of the boxes that has an adjustability to it, and feedback to the ECU. so where am i wrong?
Old 02-28-2008, 04:15 PM
EZ-RIDER's Avatar
Originally Posted by boxercup View Post
Greetings Volo,
Good Question.
modify the fuel and ignition mapping based on load and RPM " this is the cool part of the deal!!!!! re-read the post SHREDDR
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 02-28-2008, 04:40 PM
shreddr's Avatar
i read that and it doesn't make sense. does anyone have any insight on this?
Old 02-28-2008, 05:06 PM
Regnat populus
boxercup's Avatar
BMW Roundel Really Unique Modulator
Greetings,
Sure you can or automatically adjust the Lambda signal to statically alter the injector dwell.
Well that is just an old trick.
This is new cutting edge technology that I stumbled upon working on a Ducati E3 ECU development.
It is just a well programmed microprocessor.
It senses two things and delivers two things completely factored for that particular RPM and Load. It will meet the engines needs and assure the owner that his modded bike will not only perform better and cooler... It will not have those carburation gaps that everyone is complaining about and also not run too lean.
I saw a Plug n Play need when people backed away from changing an eprom in a motronic and really when the K1200X bikes came out. This is just as sweet on a K bike as it is on a G650 X-Country!
This works good on a Stock or Modded BMW as well >>>with a nice linear gain.
We have over 2 years into this and over 89,000 miles of testing including 50 hours on the dyno and more tomorrow.
Superman it is not and more power can be had out of a more adjustable Rapid bike #3.
But:
Plug N Play for $390.00 BB price. They list for $499.00! I have 4 microprocessors that cover all the current and past BMW models since the R850XX thru the HP-Sport they will release them March 15-25th, 2008. HOPEFULLY!
Priduct Liability Insurance approval and a copy preventor file are all that are missing.
Of course we do not sell these in California! It is intended for use on a a race bike piloted by a professional on a closed racing course. It is not ment for use on public roads and where the state or federal govermant or any govermental body deem it illegal with relation to emmission regulations or any other Clean Air Act. They are onlly legal in Nepal. Any misuse is at the liability of the purchaser. Consider this informed consent.
Oh, we designed it to be well hidden so no one steals it!
Never let your daughter date anyone that has one!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 02-28-2008, 06:40 PM
Snark and Soda
Robert, what sort of return policy do you have? See my post above.
Two EVs and a BRZ
Old 02-28-2008, 06:44 PM
Regnat populus
boxercup's Avatar
BMW Roundel Return???
Greetings,
Would you return it if your jeans told you it worked??
Funny late night humor. Sorry A good customer sent me a Kewl Micro-Brew! Tasty after a long day!
I always stand behind my products.
I have many in the field...the owners would not part with them. They will not return my beta versions in exchange for the production unit >>which is better.
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 02-28-2008, 07:02 PM
Snark and Soda
Oh, I'd keep it if my jeans liked it. For sure. I'd only want to return it if there was no seat-of-the-pants improvement or significant dyno improvement. I know the dyno doesn't say much about driveability, but those multiple printouts are intended to get an indication of it.
So, I'll call you and order one!
Two EVs and a BRZ
Old 02-28-2008, 07:36 PM
shreddr's Avatar
"It senses two things and delivers two things completely factored for that particular RPM and Load. It will meet the engines needs and assure the owner that his modded bike will not only perform better and cooler... It will not have those carburation gaps that everyone is complaining about and also not run too lean."
well that clears it up, Robert you missed your calling in politics. I stand by my original assesment. RPM and load are sensed by the ECU already I am guessing this thing either extneds the duration of the injector pulse, or increases the hertz. I'm sure it must be of some performance benefit, but it's not rocket science or new.
Old 02-29-2008, 03:12 AM
