too cold to go into gear??
Hi,
not sure if its just my bike or is it the same with everyone. my 99 r1100s is very difficult to go into 1st gear or anyother gear when it just fired up, need to warm it up abit before i can get it into gear. anyone same?? Thanks
I wanna Live 'til I die!
+1
I usually roll it forward a little... that helps for my bike...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
I do the exact same thing, mine is an 04.
07 R1200S 07 F800S (The Girlfriends) 06 Aprilia SR50 - Stock for now! 04 R1100S(Sold) ![]() 2007.5 Aprilia Tuono 1000R Factory(Sold) |
same here, roll it 15cms forward and it goes down into first.
Riding Nub.
Yea happens on mine as well. Roll forward a hair and I have also found letting up on the clutch just a tad (not in the engagement point) but its enough to put into first.
Willy '04 R1100S Mandarin/Gray Tampa Bay |
hmmm.... guess it happens to all 'ass'es. how abt the G'ass'es and the Rts? anyone heard of?
Private Citizen
Same Deal on the R12S, she no shift so good when cold.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S (Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling." (Roger A on moderation) "Note to thin-skins and panty-bunchers - please note smiley." |
...my solution was to move to a place where it seldomly gets cold!
ditto...
I live in SoCal and have the same issue. Before I leave for work in the morning, I have to pick up the RPM's before it will go into first.
So-Cal 1965 R69S (garage queen) 1999 R1100S (daily driver) 2001 540iA/Sport (sold) |
I just push and hold the shifter lever down while slowly letting out the clutch. Once I feel it "clunk" into gear, I pull the clutch back in until I'm ready to go.
Actually, since riding the BMW I adjusted my shift technique so I push and hold all my shifts until I feel it clunk into the next gear. Its second nature once you develop the habit.
2010 MG Griso 8V 2000 R1100S (retired) |
Riding Nub.
Are you even pulling the clutch in?
![]() I've ridden my bike in sub-zero weather without this problem. Starting it is tough, but not shifting. If you're talking about the synchros against the slop, then I can get that any time. Have you guys ever had the bike apart to find out the rigid connection between the rear wheel up to the driveshaft? All of that rolling that you can do in gear with the bike turned off is tranny slop! If you translate that travel length to the diameters of the transmission gears, it's pretty amazing. Well, to me it is. |
No Info on (t)his member
Redline Shockproof Heavy will mitigate much of these comments, as much as lotsa mileage ( that loosens it up ).
jeff
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
Yep. It is always surprising to me that people don't know this little trick.
Jim Moore Jax, FL '01 R1100S '07 CBR600RR |
i've always figured that was because sometimes it needed a little nudge, like the horse that doesn't want to get his day started.
the hold-shifter-load-tranny-with-clutch routine has never failed to prompt mine into giddy-up mode.
'04 R1100s. I changed a couple o' things. |
good tip...
Tried holding the shifter down while letting the clutch out and it's a good technique. I have only had the bike for about a month and I am still getting acquainted.
We can lane split here in Cali. Sitting at a red light, in between lanes is not the place for false first.
Next time I drain and fill the box I'm going to mix a 'cocktail' with about a pint of Dexron ATF added just for this problem. The gearbox oil does NOT lube the bearings; these are all sealed. The gearbox oil is for lubrication of the gears themselves, and acts as a coolant.
'99 Black SA "OBSSSN" - gone but not forgotten. Not all good technology is new, not all new technology is good. .........Purple is Satire......... |
I learned it from my DKW.
