-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   TB balancing....Revisited (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/408370-tb-balancing-revisited.html)
Beemercobby 05-17-2008 02:22 AM
Hi all,
All is happy in the Beemercobby stable. New coilcaps fitted, fresh set of spark plugs and a TB balance has sorted her out.
Its obvious now that the coilcap must have been going for some time hence the threads Ive started mentioning vibrations ect. The firing must have been way off.
I tested the coils at work with a multi meter, across the two outer electrodes it measured 1 ohm on both and across the middle and end of the supressor there was a a huge difference. The left measured 3.7M ohms and the right 1.9 M ohms. Don't know which was busted but a huge diff between the two.
Anyway, bikes good again so looking forward to the seaon.
BTW I fitted the NGK's the hand book recommends, NGK BKR7EKC primary and DCPR8E secondary.
Thanks, Beemercobby.
