Jeff Williams's Avatar
lifting the HP2 S
hi all,
any thoughts on lifting the hp2s .
The pipe is under the bike which leaves a bmw special tools.
makes it tough to change the front /rear tires, remove the shocks etc
any thoughts,(besides don't do it).
jeff
center stands two pieces: center stand and h adapter.
rear center stand
Riding, releases my mind from the tyranny of petty things. Thats why i ride.
2003 Boxer cup Rep
2113 Multistrada S Touring
95 R100RT Classic, a keeper
Old 06-08-2008, 08:16 PM
Uh....who me?
Bob Hancock's Avatar
Regular Pit Bull stands for the R12S won't work?
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 06-08-2008, 08:23 PM
peter f's Avatar
I used to have the later > works on left/right paralevel layouts (K/R) but the main drawback is that the sum of multiple joints...ultimately... results to a "trembling"/not rigid thing.
Pay attention to the teflon add-on paralevel insert (a fantastic idea).
R12S, black, ex Ohlins (now WP), full HPE, RB3
Old 06-09-2008, 03:13 AM
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
Pit Bull Stands will allow tire changes. If you want to get to the rear shock you can put the bike's footpegs on small car frame stands. If you have a cherry picker or hoist in your garage you can also hoist one end up by tie downs. Otherwise you're stuck with the BMW special service stand and to remove the front shock you'll still need to get creative.
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
Old 06-09-2008, 04:31 AM
Uh....who me?
Like this?
I saw Paul and Todd remove the front shock by removing the front Pit Bull, leaving the forks hanging. Very stable with the jack stands under the cylinders. This on an R12S, though. Should work on the HP2S.
Bob Hancock
Old 06-09-2008, 04:48 AM
Be advised! Remove as much of the CF as you can before slinging or lifting this bike! See the picture above.
Old 06-09-2008, 04:50 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Your always thinking Bob!
I have these. $24
You might want to add a little padding though.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 06-09-2008, 05:24 AM
Are the jugs really to be considered a weight bearing point on the DOHC? I want a real expert answer before I consider this option. It seems a bit shade-tree to me.
Old 06-09-2008, 05:28 AM
Talk Less, Say More
ckcarr's Avatar
If you want a real expert answer you should ride to a dealer and pay real tech rates. This is and always will be a shade tree board for the r1100s and r1200s.
cRaIg CaRr
Old 06-09-2008, 05:53 AM
I wasn't bustin' on you ck. Just wonderin' about the stability of the jack stands if you start removing parts from one end or the other.
Old 06-09-2008, 06:27 AM
Uh....who me?
That pic is of Nate's bike at VIR. The two guys doing the work are the real deal BMW mechanics from BMW Atlanta and a dealer in the Tidewater. Don't know if that's expert enough for you or not.
Bob Hancock
Old 06-09-2008, 06:30 AM
Cyclone Jack
hawkeyejohn14's Avatar
Man that's for sure, based on the different answers to the same question. There are a few who when they speak I listen but still I trust my dealer, just a I trusted Global and then BMW ATL. Relationships are important from both sides of this equation as well, the dealer always needs to be completely honest as does the owner of the bike and sometimes I pay a little more for security because I know my dealer will stand behind his work. Mt RT was sold in perfect running and cosmetic condition and I hope is still on the roads thanks to BMW ATL and their excellent and caring mechanics.
jc
2004 R1100SA Pacific Blue
Old 06-09-2008, 07:51 AM
I worked with Paul at Jennings GP; but also noted the pit bulls on both ends.
Old 06-09-2008, 08:41 AM
Uh....who me?
This should not be hard to understand, but maybe I fail in explaining.
1. They lift the whole bike up using the Pit Bulls.
2. They put the jack stands under the jugs.
3. They took the front Pit Bull away leaving the front end hanging.
4. Then they pulled the front shock and changed the spring.
If that isn't plain plain....I give up.
Bob Hancock
Old 06-09-2008, 09:57 AM
bob/jeff~
the stands in the picture work for me when i do it, but i've used that cool little red hydraulic jack to raise it up and then slide the stands underneath the cylinders (with some padding wrapped in shop rags). i'm guessing that jeff's bike won't allow that.
when i load the bike into the van, i also set the stands in place under the cylinders. they're not there to bear any weight, they're in place for that just in case/just because scenario if the bike jumps loose of the tie-downs.
disclaimer: i have a very ancient bike (boxer cup rep), but i think this system will work on your fancy new-fangled stuff.
i also saw a guy raise his bike with a radically different system. it requires at least two, maybe three people to steady the thing as it goes up. google "fitball", an exercise ball that you inflate with your air compressor. (about $35?).
pretty sturdy skin (i'd still pad it with some beach towels), and it's definitely a silly method and could be VERY dangerous, but it worked for him....
and yea, take off ALL the CF you can remove before you use any method.
...back to the shade under the tree...waitin' for benB/peter parts to bring the lemonade....
'04 R1100s. I changed a couple o' things.
Old 06-09-2008, 10:54 AM
Jeff mentioned part of the reason he was looking for stands was to adjust the shocks on his HP2.
This brings up a question: when we buy our bikes new from the dealer (especially the 24k HP2), why doesn't the dealer go the extra mile and take our measurements and weight to setup the bike properly before delivery? Has anyone experienced this level of service? Wouldn't it make sense if they included it as part of that pre-delivery prep crap?
Old 06-09-2008, 12:44 PM
jeff isn't adjusting the shocks, he's removing them for a few days to get re-valved and possibly re-sprung.
Old 06-09-2008, 12:47 PM
Yeah that too, for $24k you'd think the dealer would have options on Ohlins springs/valve at the time you order. Just a nit pick of mine.
Old 06-09-2008, 12:57 PM
Uh....who me?
BMW Atlanta did this for me at delivery and then fine tuned at the 600, but I had to ask. I've since fiddled with the settings to get them closer. Hard to get them RIGHT from the box I guess. Brad is right though....if it's remove the shock...gotta steady things up and raise the front and let it dangle. The other way I would do it is like this with header removal
or with my EZ-Rizer which requires a BMW fixture which I have. Don't know if it would fit the HP2S but suspect it would.
Bob Hancock
Old 06-09-2008, 01:04 PM
not many dealers will do suspension re-valving. taint easy.
it's best left to the specialists, unless you want to see the parts washer dude send a shock through the ceiling. there's some nasty pressures and forces to be wary of when playing with boingers.
setting sag is do-able, but i haven't seen anybody offer it.
bobby might know more.
the only thing i've seen lately is the solo sag setter.
http://www.motocross.com/articles/article/news/20080522/asv_inventions_solo_sag_scale-12461.html
Old 06-09-2008, 01:05 PM
