1987 951
2001f4s's Avatar
Front Wheel Bearings R1200S
I have an odd mechanical clicking from the front end and have narrowed it down to front wheel bearings. They sound easy enough to replace from looking at other posts here. My question is in regards to the source for the parts. Are these a dealer only part or can I source them elsewhere that would be cheaper.
Scott
Old 08-08-2014, 03:25 AM
Registered Agitator
sgoodwin's Avatar
I use All-Balls bearings. You can find them on ebay & other places, try google. Never had a problem with them & they're cheaper than most.
Old 08-08-2014, 05:14 AM
Boss bearing provided a good deal for my ktm, I think they sell them all. I put new bearings in the freezer and used a heat gun at a safe distance, and lightly tapped the bearings in place.
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi
Old 08-08-2014, 09:21 AM
Hi,
My front wheel bearings are needing replaced.
Are all the makes much the same?
Or can I buy bearings with no friction and a 100 year warranty from some new-tech startup made from unubtantium and the blood of 12 year old virgins that will save me fuel and make me accelerate faster?
Cheers
Adrian
Old 06-29-2018, 10:05 AM
http://www.dragbike.com/worldwide-bearings-ceramic-bearings-are-they-worth-it/
Anyone try ceramics?
Old 06-29-2018, 10:25 AM
Consensus on another forum is that they are indeed low friction, but:
- the wheel bearing friction is a tiny part of the overall friction/resistance/drag that the engine pushes against
- bearing seals are what creates a lot of drag in the bearing and ceramics therefore use labyrinth seals which are not very effective at keeping out dirt in street conditions
- ceramic bearings are easily damaged from minute amounts of contamination
Conclusion: it's not worth buying them unless you have $$$ coming out of your ears.
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 06-29-2018, 02:13 PM
Registered Agitator
sgoodwin's Avatar
Drag racers looking for every advantage use them. I've seen some scary prices on them too. For the street I can't see it.
Old 06-29-2018, 03:54 PM
Droptarotter's Avatar
I would just buy standard SKF or any equivalent good old steel bearing.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 06-30-2018, 08:39 AM
