Jeff, next time, try acetone on the metal parts before applying velcro strips. ;)
To add to this already screwed up thread, 3M 'Dual Mounts' much, much better for strength (not talking about adhesive, but the mount itself). And Jeff, likely you are correct but I have acquired some variety of the convex mirrors, and will try it myself. Hell, I can't screw the visibility any worse than it is. |
Sorry Sergio, not sure why I called them Dual Mount as opposed to Dual Lock. Anyone with a boat, etc uses them. BTW, Cee Bailey uses them for their headlight protectors too. Radio Shack sells the stuff, etc.
V1 uses the 3M Dual Lock to mount the power adapter for the V1. It's 1/2" square black. Cee Bailey's is white and round.
Ahhhh... Lars and his avatar. Thanks for the link to the original! Seeing the whole package is NICe!
[QUOTE=
To add to this already screwed up thread, 3M 'Dual Mounts' much, much better for strength (not talking about adhesive, but the mount itself). And Jeff, likely you are correct but I have acquired some variety of the convex mirrors, and will try it myself. Hell, I can't screw the visibility any worse than it is.[/QUOTE] the 3M is what i was using and blew off to Sergio's amusement:D good luck the mirrors. How something so small can be so frustrating .... |
...yet, she still agreed to marry YOU!... go figure...
I did the little round convex mirror thing and the result is a net positive but not a real solution. Since they cover a part of the mirror that gives you a good view of your elbows you don't lose much...but you don't gain much either.
Anton had suggested that a set of R11S mirrors might work. I dropped by his house the other day and matched up my template of the base of the HP2S mirror with the mount on the R11S. The holes are close but do not appear to mate up. I still think an extender will work. As to the GPS thing. I guess when you live in a part of the country with either few roads or where the map looks like a grid the GPS may seem unimportant but for exploring the back road twisties in these parts (western Va/West VA) it's the perfect tool. You don't have to stop to study the map either. http://forums.pelicanparts.com/uploa...1227068151.jpg |
Mirror extensions won't do squat, IMO. They'll raise the mirrors up more than out, and it won't be by much. I tried them on a SuperHawk, and they didn't help at all. And the mirror stalks are more horizontal on the Honda.
http://forums.pelicanparts.com/uploa...1227076671.jpg http://forums.pelicanparts.com/uploa...1227076685.jpg |
I'm still wanting to know if there is a way to integrate the GPS display on the LCD. It would be monochromatic I know.
Marine AND aviation units as well (e.g. 396, 496 etc.) Also, with marine and aviation units can subscrbe to weather. NOT weather alerts but NEXRAD radar and cloud cover, among a lot of marine info that's not needed. Expensive tho' at 50 bucks a month. The 9.95 Skywatch version USELESS, the 29.95 version 'ok', but no cloud-cover mosaic. We LD tourers like this stuff!:D:D |
I found an interesting way to mount a GPS on the HP2 Sport. Seems the two front bolts on the HP2S that hold the tank down can be removed and an aluminum bracket installed to hold a GPS just above the tank.
From the above link: Quote:
http://i286.photobucket.com/albums/l...n/IMGP1821.jpg http://i286.photobucket.com/albums/l...n/IMGP1822.jpg |
| All times are GMT -8. The time now is 06:54 PM. |
