My First Bike!
Newbi needs advice on 'Winterizing' '04 BCR
I've done a search, but can't seem to find a simple checklist of things I should do to prep the BCR for winter.
If anyone would be so kind as to give me some pointers?
Thank you!
Sean
Old 12-22-2008, 04:06 PM
time wasting tosser
Highlander179's Avatar
the only "winterizing" I've done for mine was wiring it for Gerbings.
Old 12-22-2008, 05:22 PM
Private Citizen
AZ-Twin's Avatar
If you are not going to be riding it for a few months I think it would be good to put a full tank of stabilized fuel in it, and hook up a battery tender.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S
(Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling."
(Roger A on moderation) "
Note to thin-skins and panty-bunchers - please note smiley."
Old 12-22-2008, 05:26 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
...or unhook the battery... but why would you not ride for a few months??/ The rain is only going to last a few days...
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 12-22-2008, 05:31 PM
stage1scott's Avatar
Send a message via AIM to stage1scott
get on it and leave
and ride south till the temperature suits you!! stay there or somewhere that far south! living in socal, we don't have a clue what "winterized" actually means, we just assume we should drink more when it gets under, say, 59 degrees!!
RIP Jeff Williams, founder and king of the Triple Crown & one of the best guys I ever spent time with.
RIP Jim Reid and Doug Palmer, Breakfast Boys.
RIP Brad fastest guy I ever rode with
2009 XR1200
Old 12-22-2008, 07:26 PM
unsafe at any speed
wswartzwel's Avatar
Change the oil and gear case fluids. Run some fuel conditioner through it. since it is 4 years old you should change the brake fluid too. Then remove the battery and keep it on a tender.
Bill Swartzwelder
Old 12-22-2008, 07:35 PM
unsafe at any speed
wswartzwel's Avatar
Also... a good coat of wax to protect the paint is a nice treat for your faithful steed.
Bill Swartzwelder
Old 12-22-2008, 08:05 PM
If it's going to be in storage for a long period convert your insurance to storage. This can save you a great deal of money.
Old 12-22-2008, 08:34 PM
My First Bike!
Thank you all very much for the replies. I hope it doesn't have to sit too long, but here in Kansas, it stays pretty cold til March. Its been -10 degrees the past few days with wind chill. I truly don't expect that I'll be able to ride until March, but believe me, any day over 40 and dry, I'll take her out!
So, no need to drain the gas line?
If I start it up one or twice a week, do I need a tender?
Is there a "better" brand of fuel conditioner and/ or stabilizer you guys would recommend?
Old 12-23-2008, 02:22 AM
wood-d's Avatar
When I used to store my bike, I changed all the bike fluids as part of the procedure. Do NOT start it periodically. This causes water to condense inside the engine and forms acids in the oil.
When you use stabilizer, you add it to the tank and run the engine until the stabilizer gets down to the FI's. Stabil has worked well for me for many years.
I leave the battery in and on a tender. If you do this, you might want the check the terminals for corrosion in the Spring.
If it's going to be sitting for a while, prop up the front of the bike so the front tire does not touch the ground. I don't like all that weight sitting in one spot on the tire for a long time.
Cover with old sheets. Wax is also good.
2004 R1100S (2zars)
1957 Matchless G11
Old 12-23-2008, 03:31 AM
Mark Estes's Avatar
Don't start it up once a week! That will be the worst thing you could do. These bikes motors can't take ideling for very long as no air is passing through the oil cooler or over the cylinders and the heads and cylinders will overheat. The catalytic converter can get so hot it can cause a fire. Yet the main block of the crankcase does not get hot enough for long enough to evaporate the moisture from condensation to burn off. This is bad and can cause many problems internally.
Spend the money now and get a battery tender. It will save you big bucks in the long run.
Mark
2004 R1100S, 1975 R75/6, 2005 Yamaha Majesty 400
"that spending was required to simply establish BMW in the world of WSBK from its previous position as a manufacturer who built bikes for a solidly geriatric customer base." -- SuperbikePlanet.com
Old 12-23-2008, 05:35 AM
