No Spark
Hello All I have a 01 R1100s that is not getting spark. Im not sure what to replace or what i should start testing any hel is apreciated
I have an 01 also... Did you check the basics? Bike in neutral kick stand up? Red kill switch centered? Can you hear the fuel pump run when you turn on the key? If so do you have power to the coil?
2001 R1100SA Dakar Yellow & Black - Several Modifications
unsafe at any speed
Most common problems are the wire breaking at the solder joint on the back of the ignition switch, and failed Hall effect sensor/wires. (trigger coil)
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
I'd put the hall sensor high on the list as well.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
Regnat populus
Ahhh... The power of the PPBB Board!
Good advice. ![]() The coils have also been known to fail. Check the signal to them.
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. |
