fuel delivery problem
I recently acquired a 2001 R1100S and it had been sitting for quite sometime. Prior to starting it I had planned on draining the fuel and putting in fresh fuel. My Dad the previous owner said don't need to do it just run it. Well it ran fine for the weekend and after cycling through that old fuel I put some fresh in and now it boggs out at anything over 3000rpm. Obviously there was some gunk in there and it has now clogged the injectors. Can I just run some injection cleaner after I flush the tank wont that un-coagulate what ever garbage is in there? I just need it running well enough to get it to the dealer for proper servicing.
Old 12-01-2008, 09:47 AM
Marvel Mystery Oil in the tank and run the dog out of it.
Oh, make sure the air filter is clean and no muddubbers built a nest in there.
Old 12-01-2008, 11:08 AM
Probably need to change the fuel filter too. Talk about getting to know your bike "up close and personal"....You might want to read up on doing an external fuel filter.
Valve adjustment, throttle body synch, and new spark plugs would help too.
Don't forget to change all the fluids, especially the clutch fluid.
Old 12-01-2008, 01:04 PM
I'm thinking bad fuel filter.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 12-02-2008, 02:40 AM
Responding back
good feed back Ill have the level two service once I get her running somewhat decent. Where is the fuel filter on the R I don't have the owners manual up here it's down with the bike.
Old 12-02-2008, 09:39 AM
Inside the gas tank, major pain in the butt. Perfect time to replace the battery if it's giving you any problems at all. While there, replace the air filter, and if you have ABS bleed the system and the ABS pump.
Old 12-02-2008, 09:44 AM
No Info on (t)his member
jclark's Avatar
And adding 'quick disconnects' to the fuel lines....
_________________________
jeff clark
99 R1100S
82 Alfa Romeo Spider Veloce
Old 12-02-2008, 06:05 PM
Well I have it up here now and have found out that it has a non abs battery in it. What kind of funny stuff should I expect with that. Also I dont see evidence on the calipers that indicate it is a ABS model what I do get are the ABS lights on initial start up? Is it or is it ABS
Old 01-30-2009, 07:33 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
...do you have the slotted ring on the front wheel and a sensor on the lower fork leg? Also, a look under the tank will bring you certainty... the ABS pump is a big honker, sitting in front of the airbox, under the tank... if you have a gaping hole between the Brain (the Bike's, that is) and the airbox, you have no ABS...
If you change the fuel filter, you need to run the tank dry... it's also a good idea to convert to external filter setup... do a search, it's easy.
It's a great bike and should not be to hard to make it run well again... the Battery should not be as much of a problem... the ABS bikes had a bigger alternator, though.
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 01-30-2009, 07:52 AM
