R1100S Goodies web site--questions
They have a phone number, why don't you just call them?
...being that EVERYTHING is currently marked as "Out of Stock"... and the last update to the website was in '07... I am not sure that might be a site I'd hold my breath on, though...
But maybe he has a few trinkets in his garage still...
It would be worth a call to know. I guess... |
...this Goodies-guy, Dennis Something, seems to be gone up in smoke...
...sent 'm an email ; and you will never get an answer back... ...the last time I 'spoke' him was back in 2006... |
I just bought a bike with his extreme stealth license plate kit and you can't bolt the license plate to the license plate bracket without cutting a notch in the top of the license plate. So, I was going to ask if he had corrected the problem. The PO had his plate attached with zip ties. My problem is I bought a normal sized LED lighted license plate bracket and it can't fit with the current design hole alignment and plate bracket. And if you re-drill the top holes in the stealth license plate then the lighted bracket moves down too far and there will be no stealth plate behind the bottom holes!
Answer is the extreme license plate kit's plate is too small in the vertical direction to even attach a normal license plate without cutting the top of license plate, and no way can you have an LED license plate picture frame type accessory. |
| All times are GMT -8. The time now is 10:42 PM. |
