-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   When to Repair, When to Replace (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/456242-when-repair-when-replace.html)
Emmbeedee 04-22-2009 02:27 AM
Originally Posted by onekiwi (Post 4620614)
There's an instrument cluster on ebay at the moment.Be really careful with the tab on the steering head.... they break with too much pulling!
I've bought a cluster, probably from the same vendor in the UK on eBay. Deal completed last Friday, and it should be on the way to me now. I had initially decided against that set because it looked like the speedo was calibrated in mph only, but it looks like there are kph markings on it as well.
I checked the tab on my frame and it's good, but I don't think I'll do any more heavy pulling on the bike. My replacement sub-frame should be here before long, and hopefully I won't need to do much adjusting on it.
Emmbeedee 05-06-2009 10:06 AM
Progress is being made! Got a slightly tweaked front fairing sub-frame in the mail last weekend, got the seat sub-frame tab welded last week by Johnson's Welding in Ottawa, and today the instruments I bought off eBay UK arrived!
Awesome - a brand new set of Boxer Cup instruments, and they cost me less than $200 delivered.
I have ordered Touratech Hard Part LA R1100S Yellow - Part Number: 040-1306 - to fix the slight problem with a broken steering stop, then the next thing to buy will be tires, unless something unforeseen comes up...
http://www.touratech-usa.com/shop/me...40-1306-01.jpg
Woohoo! Gonna have to start assembling now!
I've been really busy cleaning up after a "Mighty Wind" blew through Ottawa a couple of weeks ago and downed a tree in my brother's yard but that's finally done and I can get back to important stuff.
EZ-RIDER 05-06-2009 04:15 PM
T-shirt ?:confused:
Emmbeedee 05-06-2009 04:36 PM
Originally Posted by EZ-RIDER (Post 4649087)
T-shirt ?:confused:
Sorry - should be able to do that tomorrow! Do I have your address? PM me please.
Emmbeedee 08-17-2009 03:24 PM
Valve Covers Interchangeable?
This is a bit late since I've already purchased it, but is there anything which would prevent me from using a non-magnesium valve cover on my bitsa "S"? Reason I ask is that I found (and purchased) a valve cover off eBay which was described as a R1100 engine cover, and listed in this category: eBay Motors > Parts & Accessories > Motorcycle Parts > Asian > Body & Frame > Windshields
It is from a single spark model, so I think it's going to do until I find the right magnesium one.
http://i.ebayimg.com/01/!B(rj1nw!mk~...Q3)Gfw~~_1.JPG
So aside from weighing about 300 grams more, is it interchangeable?
The price was certainly right.
shreddr 08-17-2009 04:37 PM
not to be a dick or anything, but why don't you just look at em and see if they are the same. i doubt the alloy it's made from is gonna make any difference.
Emmbeedee 08-17-2009 05:17 PM
You're right, but I thought if someone else knew right off the bat from having done the switch, it would help. Thought perhaps different cam lift might have meant differences in the covers, etc, but I should just compare them.
Martin Glasser 08-18-2009 08:33 AM
MBD Still need a front tire?
I've got a sticker tire you can have Cheap!
Emmbeedee 08-18-2009 09:08 AM
Thanks anyway - I'm going to buy a nice sticky set at the first track day I do next year. The ones on the bike right now are "rim protectors" only. But you bring up an interesting subject I'll have to research: which tires to get when the time comes.
The only planned use for the bike is track days at the moment, but if I need a change from the F800GS, the S may end up on the road.
Here's my current ride.
http://f800riders.org/photoplog/imag...1_IMG_2743.JPG
Emmbeedee 03-27-2010 05:09 PM
Making Progress, Slowly
Still working on my R1100S wreck - but getting somewhere now. Bought a couple of fairings from Beemer Boneyard, but it's going to be a challenge getting the slightly tweaked fairing mount to line up.
http://lh5.ggpht.com/_ALop5GyosGA/S6...0/SANY0893.JPG
Couldn't get the same colour but not too worried about looks for now. Kinda like the yellow, but I'll work on that later.
Couldn't find a headlight for it so I was forced to order one new, and it has arrived.
Bought the Touratech steering lock device as one of the stock tabs was snapped off.
Anyone have any ideas on how best to line up the fairings? My son suggested a Park Tools handlebar/subframe bending tool as a way to tweak the mounts, and I may just try that. Looks like the tabs are about 3/4" away from where they need to be.
Still need mirrors, handlebar weights, and a few other ancillaries...
Getting interesting, though.
JimMoore 03-28-2010 03:12 AM
Here's an ad from a guy who is parting out an S. Might be some stuff you need in there.
R1100S parting out
I am parting out a 2001S (ABS) it has 72k miles on it, running bike. clipons $65 ea, handlebar light switches non ABS, non heated grip $60ea,Carbon fiber handlebar ends $70, handlebar accelertor grip $10 Front Shock $35, A Arm Black $100, Starter motor $65, Starter Motor Cover $20, Hall Effect Sensor $100, Rt Valve Cover fair $20 fair condition, Left Valve Cover fair $25, Battery $20, Transmission $450, Lf Throttle Body 45/109 $100, Rt Throttle Body 45/110 $75, Oil cooler $100, Frt Forks $175 ea. Fuel Distributer $20, Frt Brake Lines (ABS)$50, ABS lines $30, Upper Fork Bridge $75, Lower Fork Bridge $75, Wiring Harness $65, Instrument Cluster $275, Instrument Cowling $20, Headlamp Cluster $250, On Board ignition Computer $240, Plug wires $15, Clutch Cables $35, Accelerator Cables $30 with bracket, Engine w/o covers or sensor $300, Injectors $15ea., , Airbox $25, Gas Tank $225, Gas Guage $65, pump $65 Oil cooler lines $20, Exhaust Header $150, Front muffler/converter $110, Muffler $55, Clutch Lever 25, Rotors w/ hardware ABS $75 ea, Ignition Coil $35, O2 Sensor $45, Rear Luggage Tail Assembly with seat latch $75, FRont Rim ABS till 9/00 $200, Gas Tank cover $45, ABS ring $35, ABS sensor $25, Front axle $15, Front calipers $80ea., Rear Caliper $100, Rear Master $50, Front Brake Master ABS $130, Hydraulic Master $115, Clutch Slave $75, Bolts $20, frame with broken front tab $35 Rear light assembly $50, rear license plate with reflectors assembly $25 Plus shipping
Price: 0-500
Contact Rick Bierman at <accudoc1@comcast.net>
Telephone 415 450 1152
Emmbeedee 03-28-2010 11:59 AM
Thanks for that list of parts for sale - sure wish I had seen the headlight cluster before I bought it new at $700...
