Sparkplug wires
I'm going to replace my sparkplug wires and was wondering if wires like Nology are really "better" than stock. Any experience or opinions (I know...)
Regnat populus
Greetings,
Anything is better than stock and the Nology is my route~!
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. |
I'm using them with the Brisk (by Nology) non-resistor solid silver core plugs. So is Jony RR. I think Jony also has the Nology coil as well. Good stuff.
Whats the plug #
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Dy4s
Underwater basketweaver
Where do you source these from? Online vendor?
'05 R12GS '08 HP2 Sport '16 GT4 |
Sergio: You can go to nology.com and get them directly from Nology, or one of their vendors listed. Dozens in California.
Are the Nology wires replacing just the main spark plug wires or all four on a twin spark bike?
Trex |
Do not take too seriously
Twinsparks have the coil on top of the sparkplug. Just normal low-voltage wiring going to the head. The only lead you could replace on the twinspark is for the secondary plug.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
