-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Why Lord...why? (another input kaput) (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/468260-why-lord-why-another-input-kaput.html)
R69S 04-10-2009 04:05 PM
So...I had the dreaded input shaft failure last summer. Thinking alignment was the most likely culprit, I cheap'd out and slapped in a low mileage trans and clutch assm. from BeemerBoneyard. Not exactly cheap as it cost me $2k by the time I was done.
I heard it clicking (more like ticking : P ) for the last few weeks. It completely shred last night while down shifting on the off ramp. Local dealer wants $1k for labor and $1k for parts. I like my bike but I am sick of sitting on a time bomb. The posts I have seen still don't really have a pinpoint on how to fix this once and for all. It seems misalignment and possibly metal strength are subject to questioning but no silver bullet has been found. Just venting really, thanks for reading.
roger albert 04-10-2009 04:11 PM
Yikes. Sorry to hear it. That does suck. Vent away.
A used trans and and clutch assy mean you don't get much valuable data, as you didn't have a clean starting point. The other reason there is no silver bullet is that there are differing reasons, and combinations of reasons. I'd sure look at alignment when things went back together, but that not easy. Need to be a machinist and a motor builder (crank sitting not same height as crank spinning, etc) Not an easy job. Good luck!
bill pierce 04-10-2009 05:45 PM
Really sorry to hear about you having this happen 2x.
How many miles between failures?
R69S 04-10-2009 07:45 PM
Only about 2k. Still wondering what went wrong...misalignment of clutch maybe..? The replacement trans / clutch only had 14k on it. I am hoping against hope that it may be a broken drive shaft as the sound seems a little far back.
bill pierce 04-10-2009 08:35 PM
With only 2k it may be something else. Did you see this thread?
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/452179-clutch-splines.html?highlight=splines
SergioK 04-10-2009 08:59 PM
Man that sux! Twice in less than a year. I'd be pulling my hair out. At least my two failures were two years apart.
R69S 04-13-2009 11:09 AM
Hurray, it's not the input shaft! It was sounding a little further back in the drive line so I peeled the rubber boot back and sure enough the trans exit spine and drive shaft are detached. Not sure what would make the drive shaft pop off like that but I should be able to fix this without pulling the transmission (knock on wood).
Is there some type of retaining clip that holds the drive shaft on or is it just held on by friction and lack of anywhere else to go? The drive shaft collapsed maybe?
I imaging I will have to remove the swing arm to repair it. The BMW manual says I need BMW tools:
Using pull rod, BMW No. 00 8 581, and impact
weight, BMWNo. 00 8 582, pull out the swinging
arm fixed bearing stud bolt.
I did a little searching but am unsure what tools can be substituted from the local Sears. I though some one said you just need to make sure you have a 12mm allen wrench...I'll keep searching.
wswartzwel 04-13-2009 11:19 AM
There is a retainer ring in the yoke... (looks like a wedding band that has been cut) the output shaft has a groove in the spline. You force the female yoke forward until that ring snaps into the groove.
SergioK 04-13-2009 12:52 PM
I will quote you on this one day. :D
wswartzwel 04-13-2009 01:06 PM
roger albert 04-13-2009 01:13 PM
Ha,
But seriously, I don't know how you get enough longitudinal play in there allow it to back out anyway. Wouldn't have thought that was an option. Learn something new every day.
wswartzwel 04-13-2009 01:25 PM
The drive shaft has a telescoping spline in the middle, so there is plenty of space for the yoke to come off the output shaft of the tranny, or the input shaft of the final drive... Usually only happens if a previous mechanic had it apart and didn't seat the retainer.
R69S 04-13-2009 02:03 PM
That makes seance as the transmission was replaced about 2k miles ago. If it's not too difficult I would just like to re-attach it at home.
Do you think I would have to back-off the swing arm a bit to get at it for re-attachment?
wswartzwel 04-13-2009 06:27 PM
It takes a good bit of force to get the yoke pushed all the way up the shaft. You might be able to pry it up somehow through the small opening behind the tranny and in front of the swing arm. It would be better to pull things apart though, and properly inspect the parts for damage.
roger albert 04-13-2009 08:38 PM
Man, I've had those apart a ton of times, but never envisioned a scenario where all the splines could collapse enough to allow the other set to overextend that far. Looking at one that was going back together today, I can now see it being theoretically possible (which is obviously is) but I'd have bet large against it. Glad I didn't. Always something new to learn.
R69S 04-13-2009 10:42 PM
Took another look at it tonight. I can't get at it with the small opening where the boot is. I need to pop off the round plastic cover / swing arm bolt to push it forward first. I don't have the special tool I previously mentioned. Can I just use a basic slide hammer? It wouldn't be horrible if a new tool made it's way home to my garage :D. On a good note, the output splines look to be in good shape.
http://forums.pelicanparts.com/uploa...1239686911.jpg
flatbutt 04-14-2009 07:47 AM
R69S, I remember ol' Razorback really grunting on this aspect of the job. Bill didn't you use a crow bar or pry bar that was really really long?
roger albert 04-14-2009 07:57 AM
1 or 2 prybars or screwdrivers will do it fine.
Some come of easy, and some do need the grunting.
wswartzwel 04-14-2009 08:03 AM
Tom, I had the frame unbolted and back an inch or two, when we did your input shaft /clutch R&R. There is not much room with the frame assembled to the engine.
Sure you can pry it off with a couple screwdrivers.... but he is trying to put it back on. Getting behind the yoke, and being able to center it enough to force the ring over the end of the shaft will take some finesse with everything bolted together.
Try putting some grease on the end of the shaft to help thing slide better.
RBMann 04-14-2009 12:00 PM
I was in the same position and could not get the driveshaft reconnected until the swing arm was removed. Since the FD was already off it was not that much more work.
pwillikers 04-14-2009 12:40 PM
I have to imagine that it was never seated properly after the previous reassembly. Perhaps you should ask the dealer to reassemble it, properly this time, at their expense. Were I the dealer, I'd gladly provide that service.
bill pierce 04-14-2009 06:16 PM
This is a major reason why I do my own work. I just don't trust anyone else. If they couldn't get it right the first time, can they the second time?
Just pull off the final drive. Take the drive shaft out clean and lube with honda moly 60 and put it back together. Like Bill say's it gives you a chance to check for damage.
R69S 04-14-2009 09:31 PM
You couldn't be more right. At the ripe old age of 37 I have learned one thing "if you want something done right, you have to do it yourself". I called in sick today and pulled it apart. There was a little damage inside the swingarm but the splines on the trans output shaft and the drive shaft look good. Just a bunch of aluminum shavings from the yoke slapping around inside the swing arm. I made sure the drive shaft had the keeper ring engaged and buttoned it up. I still have to put on the wheel and exhaust but I want to polish the exhaust while I have it off. It's frustrating when you pay someone to do a job then have to go back and make it right. Whatever...live and learn.
http://forums.pelicanparts.com/uploa...1239769843.jpg
http://forums.pelicanparts.com/uploa...1239769853.jpg
http://forums.pelicanparts.com/uploa...1239769863.jpg
http://forums.pelicanparts.com/uploa...1239769877.jpg
