r1100s dyeing Issues
Hi, im new to this site as well as new to my 2005 BCR. but I am having a seemingly phantom issue when I am sitting at a light, The engine just dies if it is idling around 1100K rpms as if someone hit the kill switch but if it is is idling at 1500K rpms it will not die but you know it wanted too. this not really a common thing it will happen twice a weekish. The only thing that is in common when it happens are that the engine is warm and im sitting in traffic or light. Time sitting still ranges form just stopping to 6 min and when im going I can feel any hiccups or delay when I get on it. I had the dealer mess with it a few times that how I know about the not dyeing at higher idle but I was wondering what it is and has anyone else had this issue.
Old 05-06-2009, 11:49 AM
Moybin's Avatar
boxercup:
How many miles on the bike? How hot is it when you are sitting in traffic (50F or 90F)? The kill switch feel is eerily similar to how mine felt. I thought it was an issue with the Hall Effect detectors but a tune up by Gina's BMW in Iowa City seems to have cured the problem.
I would not let the engine idle for 6 minutes, particularly in warmer weather. If you know you are stopping for this long, shut it down. Only the Police RTs have factory fans to cool the oil during long periods of no-to-low speed operation. You will kill your oil quickly.
Being a BCR all you have is a side stand, correct? Are you in gear holding the clutch in or in neutral when at idle? The side stand down will kill the engine if the tranny is in gear, so a bad connection somewhere in the side stand switch circuit can cause this.
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 05-06-2009, 12:25 PM
No try, do or not do
shreddr's Avatar
I have had both my R12 and R11 stall out at street lights, not a lot, but a couple of times each. Its a little unsettling, I keep trying to figure out what might lead up to it. I notice if I slow down slowly coming to a light and let the bike get to idle easily it never dies. Sometimes I think it only happens when coming to a rapid complete stop from the higher RPMS. It may be a monstrous scavenging effect occuring that sucks the throttle body dry when it is fully closed down. I am getting the EWS sensor replaced (warranty) Saturday just to hedge my bets.
2017 R1200GSW Rallye Shreddr Signature Model
Old 05-06-2009, 01:55 PM
bacn5's Avatar
When I first installed my Power Commander I ran it with a zero map to see where the A-F ratio was with the base program. I had this happen a couple of times after a 30 minute ride stopped at a light. Each time it happened the A/F gauge showed the engine going progressively lean and then it would die. Throttle body sync focusing on the plates being identical at idle corrected the problem for the most part. Proper mapping totally eliminated it. If the plates are synced properly the air screws will be out the same amount and the twin max needle will be centered at it's highest sensitivity level at idle.
2001 R1100SA Dakar Yellow & Black - Several Modifications
Old 05-06-2009, 02:59 PM
bacn5's Avatar
Remember if the right plate is even slightly more open than the left the right cylinder will run lean.
Old 05-06-2009, 03:01 PM
The bike has 7000ish miles and I had the bike at the shop a few times they looked it over and tested the hall Effect detectors and the coils, but said with out throwing new parts into it they are not sure what it could be since nothing is testing out of range and pretty much to ride it till it starts getting worse. I was just looking to get the bottom of it sooner than that.
Old 05-06-2009, 03:03 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Who is the real boxercup?
boxercup
or
B0XERCUP
Can you say identity theft???
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 05-06-2009, 05:04 PM
unsafe at any speed
wswartzwel's Avatar
I was wondering how he created a username that was already in use?
Bill Swartzwelder
Old 05-06-2009, 07:16 PM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
All CAPS vs lowercase. (Unix systems know the difference)
Anyway, does the bike still have the charcoal cannister? If not, have all the vent hoses been properly routed?
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 05-06-2009, 07:28 PM
One the all lowercase is the real one and i have a zero instead of a o, and yes i do still have that filter on but i think i will remove it since it is just pointless weight added and i dont live in Cally.
Old 05-07-2009, 07:43 AM
what colour are you trying to dye it?
R1200S candycane
Old 05-07-2009, 08:53 AM
Regnat populus
boxercup's Avatar
Thumbs down Can you say [B]PPBB[/B] identity theft???
boxercup
or
B0XERCUP
Can you say PPBB identity theft???
Greetings,
Yes - Theft!
But what is their agenda?
To go that far?
Eh Peeter?
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 05-07-2009, 12:40 PM
proton's Avatar
Hello Rev Limit
When was the last time you blasted rev limit through at least 4 gears? These bikes need a good solid beating once in a while.
Things to crash on
2007 BMW R1200S
2008 Aprilia SXV 550
Old 05-07-2009, 01:00 PM
Man it's flat out here!
R111S's Avatar
I had this issue on my '99...bacn5 is on to it I'd say.
From my Log File:
23AUG2004 - @19,135 Miles I followed the advice from one of my British riding buddies, Chris Barnes who owns a 2004 BMW R1150R Rockster, regarding Throttle Body Synchronization. While the engine is OFF, listen to the Throttle closure to hear the Butterflies hit their respective STOPS. Make sure that they STOP simultaneously during Throttle rolloff to Low Idle position. Mine did not STOP simultaneously. The RH side hit the STOP slightly later than the LH side. Chris said to only adjust the Cable of the RH side (without the Throttle Position Sensor) and do not adjust the STOP Screws. I made the adjustment in about 3 minutes and now they STOP simultaneously
...no probs since then.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 05-07-2009, 05:44 PM
bacn5's Avatar
Yes, every time you work on the bike, and especially if you remove the tank, make sure you listen (with the engine off) to make sure that both plates are closing completely and simultaneously. Make sure the high idle lever (choke) is not engaged. It doesn't take much to upset the cable routing and usually just making sure the cables are in the correct spots is all you need to do.
But that is just step one. Step two is making sure the Twinmax needle is centered at the highest sensitivity setting at idle.
Old 05-07-2009, 06:01 PM
