Regnat populus
boxercup's Avatar
BMW Roundel BMW S 1000 RR headed for Canada.
FYI BMW Press Release:
05/08/2009
Whitby, Canada
Élite BMW supersport motorcycle to debut in late 2009.
BMW Canada is pleased to announce that the BMW S 1000 RR supersport motorcycle will arrive in Canada in the fourth quarter of 2009.
In development since 2007 and currently competing in the 2009 World Superbike Championship in full racing trim, the world debut of the BMW S 1000 RR will establish a true milestone in the supersport motorcycle category.
Combining an all-new high-performance engine with lightweight construction, sophisticated chassis dynamics and race-engineered brake and suspension components, the BMW S 1000 RR will set a new benchmark for ultra-high performance motorcycles - on both the racetrack and the road.
The 999cc water-cooled, DOHC, sixteen valve four-cylinder inline power unit is brand-new from the ground up, bred for racing, developing a maximum output of 193 hp at 13,000 rpm (rev-limited to14,200 rpm) and maximum torque of 82.5 lb-ft at 9,750 rpm.
With overall weight of just 204 kg including fuel (183 kg dry weight, 206.5 kg with Race ABS) the S 1000 RR will also take its place as the lightest motorcycle equipped with ABS in the supersports category.
The combination sets a new standard in its class with a power-to-weight ratio of just 1.05 kg and, respectively, 1.06 kg (2.31 and, respectively, 2.34 lb) per horsepower without/with Race ABS.
The new BMW S 1000 RR has been designed not only to compete in the World Superbike Championship, but to takesits place among the élite of supersports motorcycles.
“We are eagerly following the solid progress of the BMW Motorrad Motorsports team at the World Superbike Championships and excited to be introducing the S 1000 RR in Canada later this year”, stated Norm Wells, Director of BMW Motorrad Canada. “We are looking forward to having an ultra-competitive product in the supersport category and can already sense the anticipation of motorcycle enthusiasts for the arrival of the the S 1000 RR in this market.”
The specifications of the BMW S 1000 R are a testimony to state-of-the-art racing technology on all fronts – performance, handling dynamics, safety and ergonomics – not to mention the visceral packaging in the sleek S 1000 RR bodywork.
----More--
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 05-10-2009, 12:10 PM
Regnat populus
boxercup's Avatar
BMW Roundel BMW S 1000 RR cont.
S 1000 R Technical Highlights
Engine
* Cylinder axis tilted 32° forward to optimize centre of gravity and weight distribution
* stroke/bore ratio of 0.621
* Aluminum crankcase and cylinders with nikasil-coated liners
* Wet-sump lubrication using Eaton oil pump and oil cooler
* Titanium valves
* Forged, heat-treated steel 180° crankshaft
* Extra-light (334 gm) forged, heat-treated steel “crack-split” connecting rods
* Fully sequential, cylinder-specific fuel injection with integrated anti-knock control, ultra-fast processing and self-diagnosis
* Variable intake manifold length
Exhaust
* 4-into-2-into-1 system with pre-silencer, two electronically controlled interference-type butterfly flaps and rear silencer
* Two fully controlled, high-density, metal based three-way catalytic converters fitted in the pre-silencers
Transmission
* Six-speed with straight-toothed primary gears in compact case
* Multi-disc “slipper” wet clutch
* 525 O-ring roller chain
* Optional electronically controlled Shift Assistant for seamless and rapid clutchless upshifts
Frame/Suspension
* Light weight aluminum bridge frame - weighing just 11.98 kg - integrating the engine as a load-bearing element for optimum torsional stiffness and minimum weight. Aluminum fuel tank.
* Front upside-down fork with 46 mm fixed tube - with a wide range of adjustment of both the spring base as well as damper rebound and inbound control.
* ,Long (593mm) aluminum rear swing arm and central spring strut with adjustable spring base and adjustable damper inbound and rebound control.
* Ten-spoke pressure-cast aluminum wheels with 120/70 ZR 17 front and 190/55 ZR 17 rear tires
Dynamic Chassis Systems
* Four mode engine management system with Rain, Sport, Race (supersport street tires) and Slick (racing tires) settings
* Optional Race ABS with Dynamic Traction Control (DTC) and rear-wheel lift-off detector
* Four mode system fully-integrated with Race ABS and DTC when so-equipped
Brake System
* Floating double 320 mm front discs with two four-piston Brembo fixed calipers with 34 mm pistons and sintered metal pads.
* Single 220 mm rear disc with single floating caliper rear brake and sintered metal pads
Controls/Instruments
* Multi-functional instrument cluster with racing features such as a laptimer and optimum shift speed indicator
* Riding modes selectable via handlebar controls
* New generation light/indicator switch cluster positioned on left handlebar
* Quickly detachable front indicator, licence plate support and rear indicators, for easy conversion to racing use.
* LED rear light cluster with clear lens
* Optional LED directional indicators
The new BMW S 1000 RR will be available in three dramatic standard color combinations:
* Mineral Silver Metallic with swing arms and wheels in Ostra Grey.
* Thunder Grey Metallic with swing arms and wheels in Ostra Grey.
* Acid Green Metallic with swing arms in Eloxy Silver and wheels in glossy Black.
Available as an extra-cost option, the S 1000 R will also be available in the BMW Motorrad Motorsport Team colour scheme as on the Superbike Works racing bikes with paintwork in Alpine White Non-Metallic, Magma Red Non-Metallic, and Lupin Blue Metallic, with swing arms also finished in Eloxy Silver and wheels in high-gloss Black.
While Troy Corser and Ruben Zaus and the BMW Motorrad Motorsport racing team continue their assault on the 2009 World Superbike Championship, the S 1000 RR is now poised to take its place in BMW showrooms, offering an exciting new benchmark in supersport motorcycles.
The BMW S 1000 RR will be introduced to the Canadian market in the 4th quarter of 2009 and promises to be priced very competitively in the supersport motorcycle category .
BMW Group Canada, based in Whitby, Ontario, is a wholly-owned subsidiary of BMW AG and is responsible for the distribution of BMW luxury performance automobiles, Sports Activity Vehicles, Motorcycles, and MINI. BMW Group Financial Services Canada is a division of BMW Group Canada and offers retail financing and leasing programs on new and pre-owned BMW and MINI automobiles, as well as retail financing for new and pre-owned BMW Motorcycles. A total network of 40 BMW automobile retail centres, 19 BMW motorcycle retailers, and 25 MINI retailers represents the BMW Group across the country.
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 05-10-2009, 12:13 PM
Regnat populus
boxercup's Avatar
BMW Roundel Design Team
Headers:
See anything there?
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 05-10-2009, 12:18 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Which boxercup is this?
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 05-10-2009, 12:31 PM
I don't want a pickle
bill pierce's Avatar
Originally Posted by boxercup View Post
See anything there?
BMWs version of EXUP?
Old 05-10-2009, 01:12 PM
Looks like variable cross-over tuning, which seems a little different than a power-valve like EXUP, but what the heck do I know? Time to go watch the race and see how she runs...
Mike
'07 BMW R1200S
'99 Ducati 996
'09 Husky TE450
Old 05-10-2009, 01:35 PM
No try, do or not do
shreddr's Avatar
Headers:
See anything there?
turbocharger wastegate?
2017 R1200GSW Rallye Shreddr Signature Model
Old 05-10-2009, 03:25 PM
Regnat populus
boxercup's Avatar
BMW Roundel
Computer Adjusted Cross-Overs
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 05-10-2009, 03:50 PM
Regnat populus
boxercup's Avatar
BMW Roundel Ebb and Flow
Hmmm...
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 05-10-2009, 05:50 PM
S1000RR Rider!!!
Jonas The Swede's Avatar
Post Read my thread with all the details to know more!
From my thread with all the details:
"Innovative exhaust system with interference pipe butterfl ies for optimum power and performance.
Made completely of stainless steel, the exhaust system featured by the S 1000 RR is designed consistently for optimum power and performance. It works according to the 4-in-2-in-1 principle with four individual manifolds of equal length fi rst merging into two pipes beneath the engine block and then extending into a large-volume pre-silencer. From there the exhaust emissions flow through a very short and dynamically designed rear-end silencer to the outside.
A homogeneous power and torque curve ensuring optimum rideability is acknowledged as the requirement for sporting performance on the road and fast lap times on the track. Precisely this is why the exhaust system featured on the S 1000 RR comes with two fully controlled interference pipe butterflies housed in two connection pipes for the two outer and two inner manifolds, in the immediate vicinity of the exhaust ducts. As a function of various parameters such as engine speed and the position of the throttle butterfly, an adjuster opens or closes these flaps, allowing exhaust gas to flow freely between the two manifolds or, respectively, interrupting the flow of gas. This coordinates the sequence of oscillations in the exhaust gas mass flow, reducing exhaust gas counter-pressure at the decisive point (like on a racing muffler) and increasing the cylinder charge accordingly.
This factor alone makes a signifi cant contribution to the very high standard of
homogenous overall performance offered by the S 1000 RR."
*****First BMW HP2 Sport owner in Scandinavia! *****
Motto: You win some, and you loose some... you can't loose 'em all!
Quote:"And, just in case anyone is wondering, braking deep is easy when they don´t work....." - Brian Parriott
Old 05-10-2009, 06:29 PM
Deans BMW's Avatar
The PDF of the complete specs. Some 20 pages or so.
http://mcnews.com.au/2009_Bikes/BMW/S1000RR/BMW_S1000RR_Detail_MCNEWS.pdf
Dean O
Copperhill,Tn
Founder, San Jose BMW
www.motorcyclistcafe.com
www.sjbmwracing.com
Old 05-10-2009, 06:40 PM
Uh....who me?
Bob Hancock's Avatar
It'll be interesting to see how the aftermarket "improves" this exhaust set up.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Uh....who me?
Thanks Dean. Quite an explanation of what makes this thing run. But no heated grips or 12V accessory plug or bags and I'm sure the mirrors will only provide the rider with an excellent view of the inside of his elbows.
So.....note to self.....don't be too annoyed when new buyers yack on about this.....remembering that not all with funds are worthy.
I sure do want one though. Wish I had the talent to use it.
Bob Hancock
Old 05-10-2009, 07:06 PM
S1000RR Rider!!!
Thanks for reading my post... ;)
Dean, Pdf already posted in my thread... but what the heck, no one seem to read it anyways... haha
Old 05-10-2009, 07:28 PM
Top of the Valley
MaineRoads's Avatar
Price???????Yeah, I know, within a few thousand....
Post quality rating of .01792 or less.
2010 K1300S
Old 05-10-2009, 08:44 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Hmmm, let's see... the signature does not give it away?
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 05-10-2009, 09:29 PM
Deans BMW's Avatar
The latest info that I have is that the price in the US is to be within $1K of the Yamaha R1. Don't have a clue as to how equipped at that price.
Dean O
Copperhill,Tn
www.sjbmwracing.com
Old 05-11-2009, 06:45 AM
850dunstall's Avatar
crack rods tech
Porsche has been using the crack rod technology since the advent of the boxster,
it sounded impressive but i'm not so sure it has stood the test of time from an owners perspective...
claus
IBA, 04r1100s, 11f800st, 74norton, 05f650gs
auf Adlers Fluegeln getragen...
Old 05-11-2009, 07:19 AM
shreddr's Avatar
Interesting link, on the + side it looks like they have really thought it out, they are offering up lots of CF parts and an Akrapovic titanium and CF muffler tip, which will negate the need to jettison the entire exhaust if it was even possible. It looks like there would be a lot of pieces haningn in midair if you went that route. Of course for me the most telling bit of info is the many times mentioned "compact" nature of the riding position. No matter how much I like the looks of this bike, it would probably won't make for a comfortable ride. SO I guess I can breath a sigh of relief at not having to consider it.
Old 05-11-2009, 07:21 AM
Banned
Pretty clever concept - but a trade-off of complexity for power. Introducing mechanical mechanisms upstream in the exhaust is asking for maintenance.
Are they calling the exhaust cross-over pipe an "interference" pipe?
The R1100S has a baffle with a 1 cm hole in the front exhaust cross-over. Opening this brings up the power at low rpm. But reducing the hole size brings up the power even further at peak rpm.
Does anybody know if there is a baffle in the cross-over pipe on the R1200S?
Old 05-11-2009, 07:31 AM
