Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
r1200s_qld's Avatar
Stripper exhaust stud - now what?
Hi Everyone,
I have managed to cross thread one of the exhaust studs when putting new headers on recently, and I am wondering if anyone knows how hard they are to get out?
Can I just grab the stripped end with vice-grips, and twist it out? And is the thread into the head normal, or does it turn the other way??
Any advise will be most useful,
thanks
andrew
2007 R1200S Black, Ohlins, ABS, 6" rim, Akrapovic can, staintune headers (therefore no CAT), K&N filter, single seat
2008 YZF250
Old 05-31-2009, 12:21 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Moybin's Avatar
andrew:
I vote against the brute force method. If you want to remove the stripped stud I would get a good penetrating oil (not WD40) intended for loosening rusty fasteners, drown the joint for at lest 12 hours, then apply torch heat to one side only of the flange the stud seats into. This combination should loosen the stud enough that you can back it out with a wrench.
Otherwise your next step is going to be the insertion of a heli-coil into the flange to repair that damage, too. And you might be looking at that anyway.
'99 Black SA "OBSSSN" - now in Nail24's stable
Not all good technology is new, not all new technology is good.
Old 05-31-2009, 05:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Dismembered
GotRoad?'s Avatar
PB Blaster worked when I removed the exhasust studs on my R1100S
farkled '04 R1100S SOLD!
2012 Ducati Multistrada Pikes Peak (#072)
"It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams
Old 05-31-2009, 05:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Moybin's way is he best. I replaced all of the exhaust studs with longer ones to accommodate the SJBMW exhaust accelerators. I used the double nut method to remove the studs after squirting them with penetrating oil.
Philip
Old 05-31-2009, 06:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
r1200s_qld's Avatar
thanks all, I will soak her for next day or so and have a go at it mid week.
2008 YZF250
Old 05-31-2009, 04:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
turboflyer's Avatar
Might also give the end of the stud a sharp rap with a hammer prior to taking it out. If you have done all the above and the stud still does not want to turn fairly easily, heat the area around the stud again. Good luck.
Old 06-01-2009, 06:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Registered felon
Rapid Dog's Avatar
...maybe I need to get my head outta the trash, but i swore you said something about dancing...
... old fool in asschaps hawkin' R11S CNC BARBACKS...een snelle hond is moeilijk te vangen ; hij hangt zo soepel aan het gas!
'05 R1200RT/'06 MTS1000-off to San DiegoS/'81 R100RS-off to Minnesota/'06 Orangeboom-gone to Michigan/'05 R12GS-up in NorCal/'91 R100GS Derelict-alive in Iowa/-4 R1150RT SJ Special-Seattle bound/'01 R1100S-somewhere in SF/'78 R100/7-RS- alive and well in Denver
Old 06-01-2009, 11:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
groundhog
stud removal
The safe way to get it out is to spray with wd 40 or some penetrant and use a stud extractor. Looks like a socket with fingers inside that tighten on the stud as you back it out. They work very well.
Old 06-01-2009, 01:31 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
you're not alone rapid.
enticed by the headline and the word "stripper", i opened the thread to find the following:
"drown the joint for at least 12 hours"
then...
"thanks all, I will soak her for next day or so and have a go at it mid week."
and finally:
"Might also give the end of the stud a sharp rap with a hammer prior to taking it out. "
so...i dunno....i'm with you.
maybe pictures would help us?
'04 R1100s. I changed a couple o' things.
Old 06-01-2009, 01:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Registered Agitator
sgoodwin's Avatar
stripped studs, penetrating, insertion, soak her, double nut? I can't imagine where your heads at?!
Old 06-01-2009, 07:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Registered felon
Rapid Dog's Avatar
...aww this thread is screwed...
Old 06-02-2009, 06:06 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
r1200s_qld's Avatar
Got the stud out! The two nuts on the stud trick did not work because of the damage to the end of the thread, so I disconnected the battery, and got out the arc welder and just welded the nut in place, and hoped that no stray electric flow got anywhere near the computers.
But all is well, stud replaced, and bike is running just fine.
thanks again to those that offered advise
2008 YZF250
Old 06-06-2009, 02:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
