				low speed stumble
			We have a 2000 1100s that runs really rough between 2,500 and 3,500 rpm. The motor is completely stock and is low mileage. The bike idles and will pull cleanly at higher rpm.
				We have replaced the fuel filter and plugs. The fuel is new and the air filter is clean. A simple plug test by holding the rpm range while the engine is rough running shows a lean mixture with white spark plugs. Any suggestions for a fix? Thanks, -dan  |
			 John, Jacksonville, FL
			Dan, I'm a relatively new member on this board so not meaning to preach. But, filling in your profile, location, etc. might get a better response. In fact someone might be near you and willing to help. Just a suggestion, certainly not mandatory.
			Sorry I can't help.
	John Palamaro Jacksonville, FL, USA (NE FL) '09 HP2 Sport #106 '09 R12RT, Full Remus '07 GS Adventure (With McCruise, Full Remus)  |
			 Underwater basketweaver
			My bike had a weird idle and displayed the same symptoms - odd since it ran fine at higher rpms.  It turned out to be a very minute crack in the shielding around the spark plug wire.  New wires and the problem went away.  Are those the original almost 10 year old spark plug wires on the bike?
	'05 R12GS '08 HP2 Sport '16 GT4  |
			+1 for SergioK.  I'd check the spark plugs too.
	2004 R1100S (2zars) 1957 Matchless G11  |
			The bike has new OEM plugs.
	In addition to the fuel and air filter I have now checked valve lash, checked the tps voltage, sync'd the throttle bodies, and reset the idle bypass screws. Bike is still runs like crap above 2,500 rpm. Any suggestions?  |
			You sync'd the TB's at idle and at 4k rpm?  Idle set via bypass screws, 4k set via cables.
			I have followed the online methods for tps and throttle sync. The OEM "paint" is still present on the tps mounting screws and the left side throttle stop screw. The tps voltage is .380 volts.
	I set the idle screws and the right side throttle cable to sync using a mercury vacuum gauge.  |
			Check your spark plug wires and then the coil.
	I'll bet that's where your problems are.  |
			 Man it's flat out here!
			Run some Chevron Techron Fuel System Cleaner through a couple tanks.
	"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD  |
			 Registered Agitator
			Maybe it's just getting old like Bill's dad, that happens more then!
			Still no luck.
	Last night I disconnected the battery to clear the adaption table and reset the cpu. Then unplugged the o2 sensor from the harness. The bike still will not run between 2k and 3k rpm. It idles at 1k and will run above 3k. Any ideas?  |
			I'd go back and resync the TB's at idle.  Confirm you have no spark plug ignition leaks (read-bad spark plug cables).  Adjust the throttle cables at 4k rpm.  Check fuel injectors for correct spray.
			+1 on above, but if your hole in performance is from 3-4k, then sync your cables right at the start, or in the middle of that (3000-3500rpm)    The problem with syncing up at 4k, where many people intuitively believe is correct (but isn't ideal) is that the butterflies are open far enough that tiny differences have little effect anyway, and are lost in the noise of other intake/head/exhaust flow differences.   Note, plenty bikes sync well there, but you should experiment with the sync point here, perhaps going as low as 2500-3000 if need be (which will work fine, if your idle sync is truly good.
			Sparkplugs DO need to be checked, but they don't often cause such a truly severe, but narrow and well defined (both in terms of rpm) dropout. Still worth checking though.
	99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator,  |
			Thanks for that adjustment tip Roger.  Gonna make a mental  & paper note of that for my next TB sync.
			When I first read this it sounded like the classic lean surge we know and hate.  Solved mine with the Power Commander.  Recently I have been messing with the PC map to try and get back the gas mileage I lost in solving the surge problem.
			Good luck with your issue, whatever it turns out to be.
	RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.  |
