Warnig triangle light.....
Red triangle warning light came on the over day on my 2003 BCR. All the manual says is there is a problem which if left unresolved could affect the bike........?
Has oil, has brake fluid, ABS works, runs fine.
Any suggestions of what the little red triangle could be ?
Old 10-10-2007, 01:58 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
...Hey, pericep... which isle? Used to go winsurfing there GC, Teneriffe and Lanzarote... loved Pozo... and Las Americas and Medano... man, fun times... Fuerte was good too, but to crowded...
Sorry, with the light, I can not offer any help.
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 10-10-2007, 02:31 PM
Gran Canaria. Given up on windsurfing, trying kitesurfing now (easier to be mediocre at !)
Old 10-10-2007, 02:34 PM
signit98's Avatar
Actually... a friend of mine spends his winters there... maybe you'll meet him Kitesurfing some day... Armin Loose... German guy.... lives 1/2 year on GC and the other half in Germany... Sylt.
I kitesurf... fun sport, better here in San Diego, as there is never enough wind for windsurfing... but, have been out of it for a while because of a couple of knee surgeries... hope to be back at it by winter time!
Old 10-10-2007, 02:44 PM
Ummm . .. are you talking about the hazard flashers?
Old 10-10-2007, 04:01 PM
Motorradfahrer
Eisernkreuz's Avatar
Send a message via AIM to Eisernkreuz
that would be hilarious.
-Miran
99 R1100SA
Old 10-10-2007, 04:25 PM
It would indeed be hilarious, but no, I'm not talking about the hazard flashers !
Old 10-10-2007, 11:20 PM
...elica rossa...
RoLoo's Avatar
Originally Posted by pericep View Post
...any suggestions of what the little red triangle could be ?...
...I had that once, and it turned out to be a 'kaput' brake light...
Have a nice day !
Ron.
R1200S + R1200RT
Old 10-11-2007, 01:47 AM
MoDog's Avatar
If it's not a bad brake light bulb, it's often a precursor of battery failure. It seems to happen when the battery is in the in between stage of not holding the steady charge of a strong battery but stilll has enough charge to keep the battery light off. If you keep the battery tender hooked up between rides, it should cure it for a while.
Orange '08 KTM 990 Adventure for fun in the rough stuff
Patientlty awaiting an R-bike sport tourer devoid of servos and EWS
Old 10-11-2007, 02:37 AM
I had this very same issue but only until the bike warmed up. It was intermittent at first and the manual indicated that it meant a failure of the brake/tail light. A quick walk around confirmed that both elements of the bulb were actually working.
When I was in having the brake fluid flushed, I had them interrogate for codes from this warning light. They said it was showing a voltage drop and that I should put the battery on a tender.
Here is the thing, I always plug the bike in when parked in the garage, so with the battery being 6 years old, I figured perhaps it was on the way out. I didn't want to get any ABS faults, so I replaced the battery. I still had this issue every morning.
So I thought about it and figured, could this thing be smart enough to be telling me that although the bulb hasn't actually failed yet, failure was just around the corner?
So I replaced the 5 dollar bulb and voila, the problem went away!
2009 F800GS, 2003 BCR, 2006 R1150R, Victory Hammer.
Old 07-02-2009, 06:05 PM
time wasting tosser
Highlander179's Avatar
there's a built in safety feature with the tail light bulb. if one filament burns out, the other filament does double duty as brake light and tail light. when you check to see that both are working, they will, but I guarantee one filament is out on the bulb itself.
other things to check are battery, and that the ABS unit itself is full, not just the reserviors.
99 out of 100 cases are one of these 3
Old 07-02-2009, 06:28 PM
Cyclone Jack
hawkeyejohn14's Avatar
Same here...
If it is the bulb, do not handle the new bulb with bare hands or the the oils on your fingers will make short life of the bulb or the brake light part anyway.
jc
2004 R1100SA Pacific Blue
Old 07-04-2009, 10:51 AM
EZ-RIDER's Avatar
Would the use of LED brake light bulb do the same thing
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 07-10-2009, 05:20 PM
Without some sort of resister or load equalizer associated with the LED array, I would guess yes it would. An LED uses much less power than a regular bulb which may make the computer think it is a blown bulb.
Old 07-11-2009, 08:09 PM
Cyclone Jack
not my 04
I just put my hand back to the tail light and apply brake, no brake light, filament is out. I can easily see my tail light is still working, but there is no double duty on my 2004 as you stated.
jc
Old 07-12-2009, 10:19 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
Yeah, that never happened on my 2002 when my brake filament burnt out. Changed the bulb and all was well.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 07-12-2009, 10:24 AM
