Stored bike won't start
I parked my R1100S for about 9 months while I got married and moved. Yesterday I tried to start it. I siphoned out the old gas and replaced it before trying to crank the engine. The old battery would not crank the engine or light the headlamp, even though it had been on a battery tender the whole nine months. I put in a new battery and it cranks the engine briskly, but the bike won't fire. All the lights on the dash look normal, and the fuel pump is normal in sound and duration. I pulled out a plug (right side) and it was dry and clean. I don't think fuel is getting to the plugs. Is this likely to be a fouled fuel filter, fouled injectors or something else?
Old 08-25-2009, 08:00 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Sounds like the fuel is getting stopped somewhere... probably the injectors... might be the fuel filter... you might want to start with investigating the fuel flow.
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 08-25-2009, 09:07 PM
No try, do or not do
shreddr's Avatar
look and see if there is a mouse nest in the airbox
2017 R1200GSW Rallye Shreddr Signature Model
Old 08-26-2009, 05:18 AM
Pull an injector and see if you're getting a nice strong spray.
Old 08-26-2009, 05:49 AM
Or exhaust, plugged exhaust will cause a no start too.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 08-26-2009, 06:18 AM
signit98's Avatar
You guys crack me up with the mouse next theory...
Old 08-26-2009, 07:51 AM
KMoore's Avatar
I think there is a thread about it somewhere IIRC.
Here's one Winter storage tips
Looks like the R1100S is safe though.
Kevin Moore
Old 08-26-2009, 08:15 AM
Most likely is mechanical/electrical and of course that is the first path, Air/fuel/compression/spark.
But it is the odd ball stuff that gives most technicians fits, finding the unexpected is always tough.
Old 08-26-2009, 08:27 AM
Snob Pirate
geothepencil's Avatar
Mice regularly build fortifications in the fins of my lawn mower boxer engine as well as snacking on tasty wiring including the gourmet spark plug wires and caps. And they ate the air filter in my Olds one time too. No bike damage so far (that I know of).
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic
BMW/Yamaha/Suzuki
I've been ionized, but I'm OK now.
Old 08-26-2009, 08:38 AM
roger albert's Avatar
I clean about 4, of either those, or acorns or wasp nests out, each year.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 08-26-2009, 09:21 AM
Pull a plug on each side, insert a 1/2 oz of fuel, reinsert the plug and she what happens. If she fires do the Ralf stuff. My tip saves the tear apart time.
Old 08-26-2009, 09:47 AM
When you pulled the plugs did you check for spark? If you have spark, good. Next thing to check is fuel. Did you use fuel stabilizer when you stored the bike? You might have gummed up injectors or something else stopping fuel upstream.
Old 08-26-2009, 09:56 AM
RBMann's Avatar
Easier to spray starting fluid in the front of the snorkel.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 08-26-2009, 10:11 AM
Agreed!
Old 08-26-2009, 11:18 AM
Ghost Spoiler
chewie's Avatar
Old 08-27-2009, 01:47 AM
Gotta love the humor in the name of that.
Old 08-27-2009, 05:02 AM
Fwiw, it is pretty rare for modern EFI injectors to fully clog, leaving NO smell or hint of gas, and NO vague coughs or near-starts. They nearly always fail as a poor pattern, or even partially open (i.e. injector valvetip stays partially open even when it's getting no signal) which leads to extreme richness, and often a partially external-combustion engine. Several times, I've seen the cat or mid-pipe (and headers) glowing bright red, and some plastic ending up melted.
Worth checking the spray, of course (and cleaning the injectors) but this isn't the most common failure. The 100 or so PSI involved tends to self unclog to at least a crappy pattern.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 08-27-2009, 11:59 AM
