Fork caps
Does anyone know off the top what size thread the fork caps have? Ztechnik mounts use them, but I'm not paying $100.00 to mount a $100.00 GPS. I'm trying to come up with a decent GPS mounting solution and it would be the easiest to utilize these thread posts. I've already built a RAM system online going another route, but I'd REALLY like to use these. It doesn't appear that RAM makes anything that would thread onto them anyway, but I might be able to come up with something myself if I knew what they were. I've spent the morning going through all of my machine nuts and I have none that screw on there - metric or standard. For size starters, I can start a 5/16" nut on there, but of course the threads are wrong because I'm sure these thread posts are metric. Any help would be appreciated. If not, I'll make a trip up to Fastenal to see if they can help. I just hate bothering them if I'm not going to buy anything.
Thanks!Matt |
unsafe at any speed
The little brass stud that the plastic cap screws onto will unscrew from the aluminum cap.
The female thread in the aluminum cap is 5/16-24 NF The male thread on the brass fitting that the plastic cap screws onto is the same as a schrader valve. But I would not use the brass fittng to support a mount.... Remove the brass piece and mount your fixture to the aluminum cap via a 5/16-24
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
No try, do or not do
Check out what I did with the fork cap and a stock mounting bracket. It cost me $0.00 because I had the bolt already, if you don't it might cost you $0.50
Garmin Quest
2017 R1200GSW Rallye Shreddr Signature Model |
unsafe at any speed
Matt |
Matt |
![]() Matt |
unsafe at any speed
I put an oring on my mount bolt (the 5/16-24) and screwed it in hand tight.. I wanted to seal it, to keep moisture out of the forks.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 09-21-2009 at 05:34 PM.. |
Do you have rapid risers?
This is what I did.
Well, I found what I was after. I e-mailed RAM and they do have a 5/16-24 threaded female ball. However, they do not have a 5/16-24 threaded rod with a RAM ball which I was advised to go with.
http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045051053056085/Default.aspx So theoretically, one could unscrew the fork cap, screw on the mounting ball - done. However, I'm being told not to use the brass filler bolt in the fork. I assume because of strength reasons. I'm wondering why, and is there another way I can do this while using this option? Matt |
I don't want a pickle
Here's what I did. My original mounting plan did not work out as planned, so I just used the threaded hole under the OEM triple clamps. Not sure why those holes are there, but it's a good thing! There's one on each side. Not sure what size, I just looked through my metric machine screws and found one that fit. Forks are turnable (surprisingly) in both directions with no interference with anything.
![]() ![]() ![]() Yeah, yeah. It's not a Garmin, and it's not even waterproof. But, it'll work for me. If it starts raining I'll just throw it in my pocket or tank bag.Matt |
I bought this to use for my radar detector and GPS.
Techmount & Cords When I need a GPS, I'm not going very fast and don't need a detector. I put 3M Dual Lock on on it and also on the bottoms of my detector and GPS. Best money I ever spent. Just did a trip to LA and back using the detector on the hwy. and the GPS in the city. Worked like a champ. It's easy to adjust to deflect the sun, doesn't bounce or rattle. Couldn't be happier.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
unsafe at any speed
So buy the Ball with the female thread... and tell me how long you want the ball above the fork cap and I will make, and mail you a 5/16-24 stud with orings. No Charge BTW....
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 09-29-2009 at 08:25 PM.. |
Good thing I ordered the other mounting option. The top thread appears to be 5/16-32. Being advised not to use the brass fitting anyway, this would not have worked. I'll PM you about the stud, as I would be interested in the original mounting option.Matt |
Didn't see this...
What year? I'm at 102000 on my 01.
Bummer! But it is good to see another S that's ridden and not a garage queen.
I like that. Did you buy the parts or make them?
