Booster Plug
Have you guys seen this? http://www.boosterplug.com/index.html
It looks like what one of the members here had made. OwenM, I think? Any thoughts? Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat Last edited by Droptarotter; 12-19-2009 at 08:58 AM.. Reason: text |
Underwater basketweaver
There's a thread on ADVrider right now regarding this. Isn't it just a resistor to fool the OAT sensor?
Yeah, it looks adjustable, though? Edit............Oops..........not adjustable.
So to start a lively thread...........how would this compare to the FRK? Flame on!!!!!! Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat Last edited by Droptarotter; 12-19-2009 at 09:59 AM.. Reason: text |
Hey, this $.10 resistor is only $150.
Website put online only a few days ago, 12/08/09. And unless someone has dissected the FRK and will admit it, comparisons and claims are ALL BS. Keep the spam, Roger, it's more entertaining.
tm (R12, R11, R1) + 00 then S, S, /7 |
Here's another one..........only much cheaper........Fyyff Thermistor Thread For Gs - ADVrider
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
No try, do or not do
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 12-19-2009 at 10:08 AM.. |
I wanna Live 'til I die!
Must be true then...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
It was mentioned somewhere in the bowels of your FRK thread. Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat Last edited by Droptarotter; 12-19-2009 at 10:26 AM.. Reason: text |
it was interesting that in the FAQ they bash the FRK about its microprocessor function. "Competitor plug-and-play products claim to include microprocessors and the ability to read RPM from a sinus wave in the AIT line? Bull**** !! Sorry for using bad language, but it's the only word I know that really describes this kind of statements."
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 12-19-2009 at 01:00 PM.. |
Anyone know someone at MCN? . They might get all of them and do some real (world)testing?
LT |
Do not take too seriously
I like how he says it's a 10 cent resistor, and then tries to sell it for $150. Gotta admit, that's balls.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
Dont taunt happy fun ball
The FRK tricks the ECU into thinking it is always a very specific, fixed, colder temperature, thereby tilting the ECU fueling map to richen the mixture. The FRK makes the ECU think that it is always a specific temperate, weather is is 110F out of 40F. Always, no matter what the ambient temperature is, the FRK, with its mysterious electronics, delivers a spoofed 25F to the ECU. The Boosterplug uses the existing, stock, Bosch AIT, as well as an external, temperature dependent resistor (called a NTC sensor) to vary the amount of electrical resistance provided to the ECU which then tilts the ECU map to provide a richer mixture. The net result is that the Boosterplug will provide a much more consistent fueling over a much greater range of ambient temperatures than the FRK will. Brilliant.
I am still trying to understand this.................I guess I should have gotten my Grade 10? Cheers
let's turn this into another 600 post FRK bashathon!
2017 R1200GSW Rallye Shreddr Signature Model |
The Boosterplug does exactly what the FRK does, except it has the added ability to adjust for different ambiance temperatures.
Game over for FRK. |
Andrew please don't take this personal but unless you've tested both products all you've proved is that you can recall selling points and believe one over the other.
I have tested the FRK on a BMW with both a GS-911 an well as a scope. I know exactly what it is and what it does to our BMW ECU's. Regardless of what the claims of the marketer of the FRK may be, the resulting effect to the ECU is what it is. The FRK is simply a devise that provides resistance to the AIT circuit, thereby enriching the lean fuel mixture. It essentially "tilts" the ECU map. That's it. That's all that it does, and all than it can do if it is attached to the AIT circuit. Period. The Boosterplug does the same thing as the FRK; it provides resistance to the AIT circuit, thereby enriching the mixture. Certainly no rocket surgery here - this technology has been around since the advent of fuel injection. Without getting too deep into the weeds here , the big difference between the two is that is that the Boosterplug compensates for different ambient temperatures via its external NTC resistor, whereas the FRK is designed to maintain a constant 25F temperature, regardless of what the outside temperature is. That is the difference between the two products. |
I have already looked at the idea of using a thermistor in place of a fixed or variable resistor (its an obvious option) but the ones I had in my parts box where not suitable.
One way to get a thermistor with a suitable temperature coefficient is to buy a second and possibly a third genuine BMW sensor and put one or two in series with the original sensor, that should give good tracking over temperature. At the moment I am happy adjusting a variable resistor as necessary while I ride.
R1200GS R1200RT Aprilia RSV1000R Factory R1200S (sold) Ducati 1098S (deceased) Last edited by OwenM; 12-19-2009 at 08:55 PM.. |
Andrew, have you tested the Boosterplug? I think you need to before you claim it's over for the FRK.
Andrew: How did your $20 experiment work out? I'm watching the snow fall in increasing quantities and thinking of more winter projects...!
Ride Safe, Saint '02 R1100S - sold '07 R1200GS, '09 XR1200 |
