 broken front frame
		Has anyone broken the front frame lug that you bolt the fairing bracket to? Is there a fix for this problem? Bike is a 1999 r1100s.
	thanks vpilot  |
 I had a broken one.
	Although I've heard welding has been done successfully, I went to three welders who said they couldn't weld it... Beemerboneyard has the frame in stock.  |
 Broke one with the deer strike.  Searched Ebay, then got one from a fellow Pelican!  I found a welder to fix my lower rear subframe tabs.  He did a spectacular job and would have been able to weld the part instead of my buying a replacement.   He's a good friend and did the work for dinner.   Wish I knew of his mad skills earlier.  A good welder would be able to build up the aluminum, grind the sides flat, and redrill a hole.  That's how we fixed the frame tabs.
| All times are GMT -8. The time now is 02:52 PM. |
