Burgundy Topz S.C.
Battery issues
Hi All,
I have done a search and I have not found an exact match for my issue...so I post. Yesterday, I was riding home and the battery indicator light came on. The top-most light. Later, the bike died. Upon consulting with a fellow S owner, I was advised to change the battery. I just installed a brand-new, charged, Interstate battery and the indicator light is not turning off when I rev it up. Also, the ABS lights are flashing on and off in an oscillating fashion...which means low battery, as far as I know. What am I doing wrong? Or, do I have a different problem? Thanks, PT
99 R1100S If "Ctrl+S" saves, what does Jesus do? |
Registered Agitator
You're running a total loss system.
Burgundy Topz S.C.
Huh...okay...so 2 questions:
1. How does that happen? 2. How does one fix it?
unsafe at any speed
Check to see what the voltage is with the engine running, if you have a volt meter. or remove front engine cover to see if alternator belt is still in one piece.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Burgundy Topz S.C.
I will have to buy a voltage meter...but if memory serves, it should register at 12.5 at idle then 16.5 under throttle, yes?
I admit, I am not versed in electrical, but I assume I can test the voltage from the positive battery post, yes?
I hunt deer with my BMWs
LOL!
And yeah check the belt for the alternator.
2004 R1100SA (Street/Deer Spear) 2003 Suzuki SV650 (Track/Race CCS Expert#57) 2007 R1200S (SV650 replacement) |
Burgundy Topz S.C.
Also, granted it is a 1999, it only has 32K miles on it...would the belt really go bad?
I know there is only one way to know for sure, but I would hate to get that deep into it if I do not have to...
unsafe at any speed
Pulling the front cover would be easiest though, and probably will show you the problem... 4 screws on the front will remove the black plastic cover.
Bad belt or bad diode in alternator.
Burgundy Topz S.C.
Is the something that I can fix myself in the garage with basic tools, or is this a shop fix? Thank you, btw...
Registered Agitator
I say why let someone else f' it up when you can do it yourself. Be sure to use metric adjustable wrenches not S.A.E.
If you can put a serpentine belt on a cage, you can do this.
Burgundy Topz S.C.
With all do respect, this is Undiscovered Country for me...
What does a repair like this look like? Can I fix it as it sits, or do I have to disassemble the whole damn S to fix it?
Burgundy Topz S.C.
Please clarify...?
Belt with teeth on a car. Search for a link on here to the PDF manual. You can do it.
Registered Agitator
Mine doesn't have any teeth but it sure will try to bite you if you slip.
Easy fix, about as basic as it gets.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Remove the four 4mm allen bolts that hold the black cover onto the front of the motor. Allow the cover to fall off the front of the motor. Take a picture of what you see underneath and post it here.
Anton Largiader Charlottesville, VA |
Burgundy Topz S.C.
Burgundy Topz S.C.
