NuTTs's Avatar
HP2 Sport Maintenance
Hi, I used to own a HP2.. one of the first ones here in Spain. That bike had an unfortunate end but, I still have hopes of getting another one. Ive had a GS1200ADV and a Monster 1000s since but my thirst for a HP2 is yet to be quenched.
I promised that I would take some photos of the maintenance manual regarding the big 50,000km service and I have finally done so.
Here goes:
Regards,
NuTTs
2008 BMW R1200GS Adventure
2003 Ducati 749 race bike
1990 GSXR-750L
1974 Vespa 160GT
Old 11-16-2009, 09:02 AM
I remember your crash. Can you translate the captions.
it does show some suttle differences between the 12S and the HP2S. I immediately note thelonger rod on the HP2S.
Old 11-16-2009, 05:15 PM
NuTTs's Avatar
Hi, translated..
R1200s has cast pistons, left & right pistons are different..
HP2S has forged pistons and are identical for both left & right cylinders, at 50,000km the service stipulates changing the conrod bearings and piston.
Also at 50,000km the head gasket must be changed. Retorquing the nuts is not req'd 1,000km after the service.
The HP2S piston is 3mm shorter, and the conrods are 3.1mm longer. The cylinder walls are 4.2mm thicker.
There was a lot of hype about if this 50,000km service existed etc. and I remember having seen the workshop manual back then. I just forgot to take pictures and post them up.
Regards,
NuTTs
1990 GSXR-750L
1974 Vespa 160GT
Old 11-17-2009, 06:54 AM
macfly's Avatar
It seems that they must have really rung every last little bit out of the twin to engineer in such a drastic 30,000 mile service!
macfly
HP2.info
BMWZ8.US
LA.CA.USA
Old 11-17-2009, 11:59 AM
i think the sportiest, most powerful and lightest boxer ever manufactured, the hp2 sport features numerous exclusive details, previously restricted to racing, that were never before seen in series production vehicles.
swimming pool landscaping
Old 11-17-2009, 09:39 PM
The 30k mile top end work will prolly not be necessary on a street driven HP2S unless you keep it in 1st gear the entire time. Even if it loses 10-15hp in that time, on the street you'll prolly not notice it.
sujulcorn, welcome. Where are you located and do you own a HP2S?
Old 11-18-2009, 05:12 AM
No try, do or not do
shreddr's Avatar
bump, for you new HP2S owners!
2017 R1200GSW Rallye Shreddr Signature Model
Old 11-14-2011, 06:14 PM
LeftCoast Peter's Avatar
YAYA, you are just trying to get a fleet of HP2S Jap bike hunter/killers with light weight con rods, pistons,bigger bores, and fuel management out there. I'm onto you.
2008 HP2S Sport Touring
2009 525 Beta RR
North Vancouver
Old 11-14-2011, 06:37 PM
Old 11-15-2011, 12:32 AM
Registered ab-user
Sofatester's Avatar
No, not at all, absolutely wrong. BMW was only cautious. They wanted to avoid motors from blowing-up. Especially motors from such high-class and high-price models.
homologated stock R1200S: 122 hp DIN
homologated stock HP2S: 133 hp DIN
real life stock R1200S: 113-125 hp DIN
(difference mostly by different software versions and 3-4 hp normal spread)
real life stock HP2S: 131-138 hp DIN
(normal spread within the production)
actual tuning achievements among my personal friends and racing comrades:
R1200S: >152 hp DIN
HP2S: about the same.
New targets:
R1200S: 155 hp DIN
HP2S: 160 hp DIN
all without supercharging or turbos.
The new Woessner BigBoreKits are key measures for tuning, giving the R1200S a displacement of 1216ccm (103,0mm bore instead of 101,0mm) and together with the 128.1mm conrods a lot less weight on the crank.
The HP2S Woessner BigBore Kit lead to a displacement of 1240ccm (104,5mm bore instead of 101,0mm). Reason for the bigger bore in HP2S motors is the enlarged tie anchor clearance and the thicker cylinder wall.
Of course, the BigBore Kits are not the only measures, there's a lot more to reach that over 150 hp barrier or even break it.
But 135-140 hp DIN in a R1200S is quite easy and nothing special anymore. And up to 140 hp DIN the motors last mostly like the stock ones.
Reaching over 140 hp DIN out of a R1200S you have to work on a lot of issues to prevent the motors from blowing up.
But that's no "sorcery" and if tuning amateurs can do it, the BMW factory could do this also easily (and certainly even better if they just wanted to).
So, with 122 or 133 hp DIN nothing is "squeezed out".
Old 11-15-2011, 04:28 AM
Hmmm. From the old HP2Sport forum. I remember the first reported HP2S crash in Spain. I believe it was struck dead by a cage.
Old 11-15-2011, 04:55 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
So maybe when the time comes for the 30k 'major service' I'd go for a Wossner piston upgrade too.
'04 BCR
'05 R12GS
'08 HP2 Sport
Old 11-15-2011, 08:18 AM
shreddr's Avatar
why wait?
Old 11-15-2011, 08:22 AM
SergioK's Avatar
Cause 133hp is plenty for me. Very few places I can really 'safely' use all that power. And with ACH in my back yard, I found the 98hp from my old 11S was more than adequate.
'04 BCR
'05 R12GS
'08 HP2 Sport
Old 11-15-2011, 08:51 AM
tony distefano used to drive his factory mechanics nuts with that attitude. they always wanted to make his bike faster (usually on top end), but he stubbornly insisted on not wanting more power until he could hold the throttle on all the way around the racetrack.
that never happened, but he did win some chanpionships along the way...
Old 11-15-2011, 09:34 AM
shreddr's Avatar
maybe you need a downgrade
if enough is enough, and more is better, then most is best!
Old 11-15-2011, 09:55 AM
CoffeeGuy's Avatar
Is the HP2s faster than my new r75? My butt dyno tells me my airhead pulls 112.4-113.3 hp.
I'm going to just say that I think that's about right.
Old 11-15-2011, 11:37 AM
