Rear caliper wear from Hugger?
Hi,
At my recent service the mechanic noted that there was excessive wear in the rear caliper causing uneven pad usage.
He reckons that the Ilmberger Hugger thingy that I have is the source of the problem and has shaved the hugger where it mounts with the caliper so that they are not touching.
He reckons that this is a common problem with after market huggers....
Any comments anyone?
Old 11-14-2001, 01:32 PM
roger albert's Avatar
Hi,
Interesting (albeit annoying) I haven't seen anything of the sort on mine, but mine doesn't much rub, so who knows. I'm not sure how that wear would be related to uneven pad wear (mine wore quickly, but evenly, with the hugger having been on the last 80% of the pad-set's life)
I'll double check mine this even and see if I can provide better feedback.
What about you other Ilmberger owners?
roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 11-14-2001, 03:36 PM
No Info on (t)his member
jclark's Avatar
As long as the caliper is free to move with the Hugger on( just grab it and wiggle[ it's fun! ] ), then I would look elsewhere for pad wear.
Some other BMW Lists[ R1100R/RT ] complain about ( to them ) premature wear also.
jeff
thinks the rear caliper is great for keeping the rear disc from rusting...
_________________________
jeff clark
99 R1100S
82 Alfa Romeo Spider Veloce
Old 11-14-2001, 05:00 PM
doberman's Avatar
I have the Ilmberg hugger too, and my brake pads are wearing
down rather quickly.
They were down after 10000KM and I do not use the rear brake very much.
The caliper does not move from side to side, so yes it could be the hugger.
Anyway, I will have my dealer look at it, and if he has a solution
I will post it here.
Old 11-21-2001, 06:29 AM
Rapt's Avatar
Now you've got me wondering. I don't have th e hugger and I have almost 30,000 kms on mine with the original rear pads... I'm going to have to have a look.
Rapt
Black '99 R1100S
Mojave Beige '02 VW Golf TDI
Old 11-21-2001, 11:25 AM
pdonnell's Avatar
Snake Oil!! I put my hugger on before a new set of pads and in looking at them (very recently) there was minimal wear for 4000 miles of useage. I think there are some factors hear not being addressed. i.e. rear brake useage, severity of useage etc......
Old 11-21-2001, 11:39 AM
Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
Thumbs down
Replaced the pads at 19k mi. worn out, the local BMW shop says this is normal. I'm surprised since I rarely use the rear brakes. BTW I do have the hugger.
77 R100RS95 A6 Quattro
http://www.joesrepairshop.com/
Old 11-21-2001, 11:56 AM
pdonnell's Avatar
Hey Joe, thats about what I got outta my first set. Did you get all kinds of brake dust spitting out onto your rim with the new set of pads. I sure did and it sucks!! but then the K-Caddie does the same thing. Which due to design I am always using my rear when engaging my front. Link me up scottie!!
Old 11-21-2001, 12:23 PM
Hi,
I'm a fairly light user too, but managed to finish mine off in only 12k. It suprised me. I suspect I use them a bit more than I'm conciouss of. My dealer seemed to think replacement by 15k was normal and that I wasn't much ahead of the curve, fwiw.
later
roger
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 11-21-2001, 02:15 PM
jclark's Avatar
People who are concerned about the wear & also use a ( Ilmberger ) hugger, I suggest removng the offending piece of kit, and ride 10kKm-ish –*then report back to the list as to what you have found out.
jeff
will keep his placebo, thank you...
Old 11-21-2001, 02:58 PM
Joe Joe is offline
Joe's Avatar
Talking
Pat
I had these black splotches all over the rear wheel for about the first 500mi. it seems to have settled down now. Anyone know of harder compound pads since we don't need a lot of braking force on the rear of the bike.
BTW I have over 80,000mi on my 77R100RS rear brakes not even half worn.
Old 11-21-2001, 05:30 PM
I have 40,000 miles on my rear brake pads and they look good. Jeff
Old 11-21-2001, 07:01 PM
Brake Pads/Hugger
I've got 22,000+ on mine.....probably going to get the front and rear replaced
before I take off for trips starting in the Spring.....I'm not running a Hugger at this\
time....as always, I wait on Roger's R&D....
I'm surprised BMW didn't add that little bit of protection for the suspension
system.....knowing what dirt and grit do to moving things.....
Looking foward to more input......
Niel Hancock
Old 11-26-2001, 01:04 AM
Andrew Stemp
Guest
Posts: n/a
I tend to use a lot of rear brake and changed mine at 8000 miles. The hugger I use is not attached to the caliper at all. I did note that one pad had worn more quickly than the other, but this is apparently normal on a sliding caliper.
Andy
Old 11-27-2001, 04:34 PM
EZ-RIDER's Avatar
Lightbulb
Hey people;
Lets use our heads here,If you take the Hugger bracket which is the same diameter and you put two bolts though it and torque it, it isn't going to make a dam bit of difference.Your Mechanic is blowing smoke up your ass
TOM
Old 11-27-2001, 07:23 PM
Nitro's Avatar
I got the Ilmberger hugger and 4000 miles. My pags are as gone as gone can be... (I do use the rear a lot though)
Cool
Old 11-28-2001, 08:49 AM
Re: Brake Pads/Hugger
They did add a "little bit of protection" -- that's why we're all buying huggers! :-D
Old 11-28-2001, 10:45 AM
