Ride Italian
schoolbusbob's Avatar
Send a message via Yahoo to schoolbusbob
Oil filters
What everyone using for oil filters? I'm to cheap to keep buying OEM after the warr. has expired. Would not an R1200R or GS filter work? The K and N filters are not much less $$. Perform does not list anything. I found a internet site that says that a Purolator PL1024/PL25230, Mobil 1 /M1-102, Bosch 3330 and a Walmart/Supertech ST 3614 will work. But I can't validate the information. Can anyone?
THANKS BobL.
Old 05-04-2010, 06:10 PM
Raven's Avatar
You opened a can a worms with that question!
Wait and see what happens next!
I will just say that I have 91K on my bike and I'm a cheap ass!
Don't tell anyone, but, I don't even use BMW oil
Lets not even start on the K&N air filter topic!
Good luck dude
Don’t believe everything you think!
I don't suffer from insanity, I enjoy it!
2000 red R1100s, 1983 Gold Wing Aspencade, 2003 CRF450R, 1996 KLX 650, 2006 Ford F250 super crew long bed
Old 05-04-2010, 06:27 PM
Man it's flat out here!
R111S's Avatar
Can of worms is RIGHT!!!
I have 64K Miles on my '99 R1100S and have always used the BMW P/N: 11-00-1-341-616 Oil Filter Change Kit. As far as I can tell Mahle is the supplier and they're made in Austria. And I'm cheap too - but not when it comes to OEM Oil Filters.
On the other hand I'm using Fuchs Silkolene 20W50 Engine Oil - Fuchs is a German Oil Company by the way.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 05-04-2010, 08:34 PM
I don't want a pickle
bill pierce's Avatar
I buy them in bulk from these guy's.
BMW motorcycle parts, BMW motorcycle, Used BMW motorcycle parts, BMW motorcycle salvage
Old 05-04-2010, 08:47 PM
wood-d's Avatar
+1 on beemer boneyard
2004 R1100S (2zars)
1957 Matchless G11
Old 05-05-2010, 03:05 AM
I've been using Ol' Roy's Re-Re-Filtered oil (69 cents a quart) from 7-11 for the past 2 million miles on my S, and save even more money by removing the guts from a stock oil filter and using Dollar General paper towels every 50k miles or so. Plus, I get free spark plugs you find by the gross outside car repair shops, maybe a little rusty and corroded but perfectly serviceable. When I hole a piston, J-B Weld does the trick.
Old 05-05-2010, 04:52 AM
Originally Posted by phoenixtexoma View Post
............ and save even more money by removing the guts from a stock oil filter and using Dollar General paper towels every 50k miles or so................
Foolish to say the least, you need the toilet paper filter!! Frantz Toilet Paper Oil Filter , AND with a name like "Frantz" it must be made to high German quality standards.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 05-05-2010, 05:07 AM
Registered Agitator
sgoodwin's Avatar
Nice, dual purpose filtering!
Old 05-05-2010, 06:36 AM
turboflyer's Avatar
Its going down hill fast but they say it does roll down hill. Hey the Frantz filters do work. If fact I have quite a few about the garage. I just got tired of installing and removing and the extra service. But back on the spin on OEM. BMW does not make filters, or oil. So you can get OEM or better manufactured else where. Consider getting a tool like the one below to open up your filters. Good for inspection. I do it on every vehicle. It will allow you to physically see the construction and filter medium. You can make your own decision. K&N make a good filter as does Hiflo. One I am really impressed with is made by a company called Filtec for Honda. Need to see what else they make. The 05 R1100S filter does have a bypass valve. More of a safety feature than any thing else should the filter become clogged. Helps keep the oil flow up to speed when the oil is cold as well. When something is not understood completely folks tend to trust the manufacturer more than there own common sense. Remember use only "XYZ" oil, transmission fluid, coolant. Couldnt be they might just want you to buy there BMW oil bottled by Spectro oil, or the Honda filiter made by Filtrec. You get my drift. Under warranty sometimes your are a slave to the system.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 05-05-2010, 07:17 AM
Gasteropod Rider
Meeni's Avatar
I use mobil1 m102 for the 1100s. Its not that much of a bargain, but it saves me the trip to the bmw dealership thats in far-far-away land
Old 05-05-2010, 09:01 AM
JB Weld....name dropping elitist...
Old 05-05-2010, 09:09 AM
On a serious note...Turner Motorsport sells the OEM oil filter, their number OC 91 for $10.50 each.
Old 05-05-2010, 09:32 AM
diz plaz is cwazy
RIQUE's Avatar
I use the Bosch filters. Seem ok.
Old 05-05-2010, 09:47 AM
moze229's Avatar
I buy Bosch filters by the case from BeemerBoneyard. I'm not gonna tell which oil I use, but it isn't BMW and it isn't "motorcycle" oil
Matt
Old 05-07-2010, 06:35 PM
A Real S-Hole
zustation's Avatar
After much searching of this site when I did my last oil change, I put together this list of aftermarket filers that will work on the R1100S. I can only vouch for the Bosch though, and it will work with the BMW oil filter wrench by the way.
Mann #71216
PF1377
Purolator PL10241
Bosch 72161
Mahle OE91
K&N KN163
2003 R1100S
Old 05-09-2010, 08:45 AM
