redman9's Avatar
Manual? Haynes or Clymer or?
Can't remember which one is krahp. I do remember that either Clymer or Haynes isn't worth using to start a campfire...just don't remember which one.
I found a download of the factory manual but it is poorly laid out and severely lacking in how-tos and photos etc.
BTW 2004 R1100S twinspark
Thanks folks....
Kevin
2004 R1100S, Ohlins, Staintune, RapidBike, various tweaks
Life in the Vast lane.....
Old 05-18-2010, 08:05 AM
I've got a PDF version of the BMW Repair Manual for the S bike, and some other files I've found here and other places. If you want to download them, send me and email: jerry.duke@gmail.com
Old 05-18-2010, 08:53 AM
peter f's Avatar
The OEM repair manual is not bad - I'm talking about the R12 series, witch is rather an RDBMS type of "application" (cool gray 3d models as well) but nothing beats a Clymer manual.
Problem is that (AFAIK) there's no Clymer manual for R11 series. Next best solution: Haynes.
R12S, black, ex Ohlins (now WP), full HPE, RB3
Old 05-18-2010, 09:37 AM
HYPER K
jaytee's Avatar
Never used it but try this:
Clymer BMW R850, R1100, R1150 & R1200C* 1993-2005
Old 05-18-2010, 01:00 PM
Registered Agitator
sgoodwin's Avatar
Originally Posted by jaytee View Post
Yep that's the one I use, sometimes got to search for info but it's there.
Old 05-19-2010, 05:40 PM
Gone Bush
twodear's Avatar
I have an OEM manual for the R1100S and the separate wiring schematic booklet (in German) which I found very good but as has been said, weak on How To (I assume, because the guys using it also having been to formal schooling on repair of the R1100S).
After decoding/deciphering the electrical manual, I successfully removed about 2kg of wiring and relays. The OEM repair manual also listed torque values for everything attached with bolts.
My question is, how good are wiring schematics in the Clymer and does it have torque specs? Will I need both OEM, OEM electrical addendum and Clymer to dig deep into the recesses of the R1200S?
If enough is enough and more is better then too much should be just about right.
Member of AAAA (Association Against Acronym Abuse)
'22 H-D 'F' outfit, '46 Indian Chief outfit, a couple of early Honda Benlys, "BUBba" - R1150GS Adventure
Old 05-19-2010, 06:12 PM
HYPER K
jaytee's Avatar
I dont think clymer makes an R1200s manual - only R1100-1150
Old 05-20-2010, 08:43 AM
peter f's Avatar
Haynes does the manual for the R12S and available schematics are rather good. I don't like the fact that includes all R12 series bikes, but finding a manual solely for the R12S could be rather impossible I guess.
BMW R1200 Twins Repair Manual 2004-2006: R1200GS, Adventure, R1200ST, R1200RT, R1200S
OEM stuff (iso format, kind of "application"):
Bmw HP2 & R1200 R S RT ST GS & R900RT Service Manual 2007-2009 MULTI - Download Technical
Old 05-21-2010, 05:25 AM
