redman9's Avatar
What's with the "bleed screw" on top of the forks?
I'm not used to the telelever set-up. The little black plastic screw on caps cover what? Are those filler plugs? Nah...what are they? Manual seems to call them bleed screws. I'm lost.
2004 R1100S, Ohlins, Staintune, RapidBike, various tweaks
Life in the Vast lane.....
Old 06-02-2010, 11:55 PM
Registered ab-user
Sofatester's Avatar
It's not a bleeding screw but a vent screw.
If manual say it's a bleeding screw the manual is wrong.
BMW original Repair manual says it's a vent screw and that indeed is the function.
As long as you don't replace the slider tubes, the sealant rings between the slider legs or you discover a leak you may just forget that screw.
Old 06-03-2010, 03:44 AM
roger albert's Avatar
+1. Over time, the forks can build up some air pressure inside and it can be worthwhile venting them. I've found that there was significant pressure in there exactly once in about 11 years, so as Sofa says, you can probably just forget them.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 06-03-2010, 06:10 AM
redman9's Avatar
Thanks gents...reason being, I have now installed RD's barbacks and where I would LIKE to put them has the original clipons interfering with that plastic cap that covers the "bleed screw". I may make some caps that sit flush or??? (BMW service manual calls them "bleed screws"...?)
Old 06-03-2010, 06:45 AM
One could pull the caps entirely and replace the schrader valves underneath with an appropriately threaded bolt. Or put a little vacuum cap over the valve and dump the caps.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 06-03-2010, 07:00 AM
redman9's Avatar
I figured...and I guess I figured right.
You sir...have told me exactly what I wanted to know.
Old 06-03-2010, 08:15 AM
