I see you
flatbutt's Avatar
So educate me on brake power.....
versus rotor size. My M696 has RIDICULOUS stopping power. The rotors are large 320mm with 4 piston calipers. So is it the 4 pistons or the 320 mm or both or what? Dang this thing stops, I nearly dumped it in my driveway.
Old 06-22-2010, 09:27 AM
Yes and yes, but mostly the 150 lbs less that they don't have to stop vs the donkey. My guess is bike and rider are 75% the weight of the R11S.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 06-22-2010, 10:20 AM
Private Citizen
AZ-Twin's Avatar
It is a Ducati, they just stop better.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S
(Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling."
(Roger A on moderation) "
Note to thin-skins and panty-bunchers - please note smiley."
Old 06-22-2010, 12:30 PM
No try, do or not do
shreddr's Avatar
there is the piston size of the master cylinder factor as well
2017 R1200GSW Rallye Shreddr Signature Model
Old 06-22-2010, 12:32 PM
I see you
flatbutt's Avatar
ah ok, I need to spec that
Old 06-22-2010, 12:54 PM
The reason for that Brembo have a stock supply set up for manufacturers,the KTM RC8 has them fitted,on the outside the 1198 has the same,but Ducati stipulate a different internal spec.
Old 06-22-2010, 02:06 PM
Actually it is the ratio of Master/Slave cylinder total cross section, Pi x r^2 *x # of bores.
Old 06-22-2010, 04:55 PM
Do not take too seriously
throttlemeister's Avatar
Agreed.
Different size discs and cylinders generally only make a difference in feel, bite and force required. That difference made you almost drop the bike, not brake force. Most modern bikes, the R11S included, can easily lock the front wheel when building up brake pressure. In other words, they all achieve maximum possible braking force. Stopping distance is then decided by weight, length and CG, ie a K13R can easily out-brake a supersport bike because of its low CG and long wheelbase, which makes it very hard to list the rear. Supersport bikes on the other hand are generally not limited by braking power, but by preventing flipping over.
The reason the Duc appears to brake so hard, because it has very high bite and requires very little force to activate (1 or 2 fingers is more than enough), giving the impression of very instant and very hard braking.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 06-22-2010, 10:13 PM
The other slow speed detriment for the Duc, is the VERY small lock to lock steering angle. Don't know how many times I had to make a foot save doing u turns and slow speed parking lot maneuvers, due to the bike I was riding had very little steering angle available, or my damn oversize tank bag getting in the way.
Old 06-23-2010, 04:37 AM
I see you
flatbutt's Avatar
yup! had that experience last night . cost me a mirror.*sigh* however, I must remind myself that I dropped the donkey many times while re-learning to ride her.
Old 06-23-2010, 06:02 AM
Private Citizen
AZ-Twin's Avatar
I bet rake and trail have something to do with it also. Anyone smart enough to confirm or deny that want to chime in?
I just think of a lab in Physics class where we had to push a brick on a board with a stick, then change the angle of the stick which put more force down on the brick and made it harder to push because less force was going towards the forward motion of the brick, and more force pushing down was increasing the friction between the brick and the board.
Old 06-23-2010, 08:52 AM
Ahh, Vector geometry as it relates to force
Old 06-23-2010, 10:07 AM
