daynkc's Avatar
Low fuel indicator not working
I recently started noticing that my low fuel indicator is not coming on. Usually it comes on like clockwork between 125-130 miles but I have gotten up into the 140-145 mile range without it coming on. When I fill up I putting in over 3.7 gallons so would have thought the low fuel indicator should have come on since I'm below the 1 gallon reserve.
I have removed the tupperware and lifted the tank and check the wiring coming from the tank and going into the instrument cluster and don't see any loose connections. I have also checked the fuses and everything else appears to be working on the bike.
The bike is 2004 R1100s and the only work I have done lately is HID install and air filter replacement, although I believe I had the indicator issue before doing these two items.
Anyone else run into this issue and can offer suggestions before I take it into the dealer?
BMW R75s...
Suzuki RE-5
BMW R1100rt
BMW R1100S
Old 06-23-2010, 07:24 AM
It's a pain, but you can remove the instrument cluster and swap some bulbs around to eliminate that from the list.
Old 06-23-2010, 07:52 AM
Dont taunt happy fun ball
AndrewA's Avatar
Send a message via AIM to AndrewA
I had this same problem, and vaguely remember fixing it by installing a new relay.
I believe that you can swap these relays around to help diagnose.
This might help:
Old 06-23-2010, 08:43 AM
daynkc's Avatar
Just an update on this in case anyone else runs into this problem.
The bulb was good as it flashes on/off when you first turn on the ignition. I replaced the relay but got no change in symptoms. Talked with local BMW service department and they had to order a low fuel sensor that is located inside the tank. The part had to come from Germany but it did fix the issue. Thanks for the suggestions and local service department for getting the part as quick as they did.
BMW R75s...
Suzuki RE-5
BMW R1100rt
BMW R1100S
Old 07-08-2010, 02:37 PM
