-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Noob Questions... (please be gentle) (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/549630-noob-questions-please-gentle.html)
jaytee 06-29-2010 10:05 AM
Originally Posted by peter f (Post 5429286)
To tell you the truth for me the very first reason to use aftermarket serial ECUs is that lean mixture little matter (especially in a lean engine by design as is this case). Have no idea what amount of "safety factor" could offer the spoof devices (meaning that I have no idea what type of rich mixture can provide the BMS-K if fooled from the IAT sensor).
But the "hidden" benefit for using a successful serial ECU installation is the BIG differences at partial throttle openings - WOT charts/graphs/claims are the art of pointless.
If you are after challenges...well...you know what to do.
best, peter
I'm still a bit confused... What exactly is an "aftermarket serial ECU" and why would someone want to use it?
cageyar 06-29-2010 10:08 AM
Careful.....you're going to fall into the rabbit hole and then you never know what you find; go ask Alice.......
jduke 06-29-2010 10:09 AM
No offense to Peter, but on an R11S, a serial ECU is about as useful as a gold plated brake reservoir.
Bob Hancock 06-29-2010 12:18 PM
Before we open this Pandora's Box, look for a thread I started called FRK and the Sprocket...or something like that. It started off pretty normal and then grew. Even has a few useful things in it if you are prepared to dig.
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/462294-frk-sprockets.html
Shreddr started one too. Get a cup of whatever and read up.
cageyar 06-29-2010 12:34 PM
He has an R12S.
Originally Posted by Bob Hancock (Post 5429877)
Or 20 oz. glass of vodka....
jaytee 06-29-2010 05:49 PM
Well, you guys might not rememebr me, but I also played a role in that rabbit hole. I think I actually got in a bit of a tif with our estemed moderator.
It was a brutal Pelican coming out party for me. I came down on the side of not being impressed with whomever was marketing the FRK at the time. It's knid of ironic that I now have an FRK mounted on my bike after all of that.
Rather than open up that can of worms... I guess I'll keep using the FRK at the moment, checking my sparkplugs regularly and decide later when I have recovered from the purchase of this bike if I want to spend the $$$ on a PC and dyno tune or call it all "good enough".
whew!
JT
PS: I still have no idea what a "serial ECU" is... :P
peter f 06-30-2010 12:58 AM
"serial" is an euphemism of mine : means an ECU (or something that claims to be an "ECU" of some sort the likes of RB and/or PC) that plugs in "after" the OEM ECU and modifies the OEM ignition/injection signals according some stored maps (max 2). All these things are supposedly working in open loop. In RapidBike's case there's a great mystery (at last to me) about why works with steady L=1 values (thus requires OEM L-sensor replacement with other gizmos).
In fact only MoTec is an ECU (but...requires the hit the bank plan). That said a friend - Yam R1 retired racer - has an used M400 unit and he's willing to give it to me for free - in exchange I'll give him some concept design for his future home (my BIG troubles may start right now, maybe not he he).
But indeed this whole topic is a gigantic rabbit hole...maybe the best thing to do is to stay away from all that (maybe pointless) mess.
