iABS Pressure Modulator on 04 R11S...help
My brake failure light just came on yesterday and is flashing in rapid succession. Upon scouring the net for info, I found a post that has almost the identical issue I have, except that I haven't verified whether or not brake fluid is leaking from the front.
Anyone got and tips on troubleshooting this (veritable noob with mechanics, but I want to learn self-sufficiency). Thanks in advance!
Old 06-29-2010, 01:53 PM
unsafe at any speed
wswartzwel's Avatar
Does your brake light work? (Tail light)
Bill Swartzwelder
Old 06-29-2010, 02:12 PM
time wasting tosser
Highlander179's Avatar
how many flashes? There is a chart under the seat.
I've had the abs light go off for either tailight bulb out, or wheels out of synch from braking over bumps or wheelies. The tailight is tricky though because if one of the filaments is out, it will still have taillight and braking features.
Old 06-29-2010, 03:57 PM
Dismembered
GotRoad?'s Avatar
one if by land, and two if by sea!
just kidding. there are 2 flash speeds: 1 & 4 Hz. It soulds like you are seeing the 4Hz flash. Is your general warning light on or off? Do you have normal braking or only residual ? Are both front &rear levers fully released when the ignition switch is first turned on?
farkled '04 R1100S SOLD!
2012 Ducati Multistrada Pikes Peak (#072)
"It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams
Old 06-29-2010, 06:20 PM
My tail light does work. It reset itself after I removed all the fairing and tank, traced the wires to check for loose or severed wire, confirmed tight connecting points, checked the pressure modulator for leaks, cleaned the air filter (unrelated), disassembled the rear fairing and tail light assembly, drank a beer, did a rain dance, called on the BMW gods of troubleshooting (and consequently got no answer...need a new deity I guess), then put it all back together.
I did notice a DRAMATIC improvement in brake function over and above what it was before (cracked a nut on the tank with a full handful of brake)...
Summation...still puzzled why and don't like it. When it was malfunctioning, the flash rate was 4 Hz and the general warning light was on.
Old 06-29-2010, 08:31 PM
