rekeying system cases (bmw saddlebags)
I need to rekey the system case saddlebags for my r1100s. I can't get the cylinders out of the saddlebag. Can some one tell me how to release the cylinder so it will slide out? I know where the hole is but I can not find anything in there to push on to make the release.
I see you
oh sooooooooooooo many inappropriate jokes
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
There is an article regarding modifying the keylock cylinders to be able to remove the key when unlocked. This is a mod I have been planning to do for a while but haven't got to it. It should explain how to get the cylinders in and out as well, R-Bag Keylock Mod
Scott '98 R1100S - Triple Clamps, 10mm Shortened Telelever 2013 KTM 990 SMT, 2008 KTM 990 SDR |
Dismembered
PM Anton Largiader on this forum. He did an article on the very subject in RA Magazine, issue before last.
farkled '04 R1100S SOLD! 2012 Ducati Multistrada Pikes Peak (#072) "It is difficult to get the news from poems, yet men die miserably every day from lack of what is found there" WC Williams |
The key has to be turned to the correct position in order to depress the locking tab. Try turning key to both locked and unlocked position and depressing tab through hole. One of the two positions will allow you to remove cylinder from case.
Good luck, Black12s P.S. this is just a guess, but has worked for a topcase I used to have on my R1100RS
2007 R1200s 2002 SV650s (sold) 1994 R1100rs (sold) |
Huh?
Lars Pedersen 2002 R1100S Prep, still soldiering on. Need to ride it more. 1970 Ford Bronco, far from stock; 2005 Subaru Outback wagon, departed, don't miss it. Replaced by The Storm Trooper, AKA a bone white 2019 Jeep Grand Cherokee Upland. Vans RV-7 flying as of June 24, 2012; Too many bicycles to list. |
Did you buy another lock & key set and cannibalize it for the tumblers, or was there a tumbler kit available?
2001 R1100S |
Huh?
BMW's lock cylinder kit is part #51 252 337 270. It's been a couple of years, but it seems to me it included both tumblers and cylinders. Since the cases I had already had tumblers and cylinders in them, I wound up with some extra parts. In any case it was pretty easy to do.
I just took out my cylinder and took it to the BMW dealer and he had enough spare inserts to get it keyed to my ignition key. No charge.
Huh?
Mmmm. Free = good. Reminds me that I need to get a spare key (again).
My dealership parts guy wasn't very knowledgeable over the phone. He didn't think the cylinders were removable from the multi-function box. When I told him I've had them out and tinkered with swapping the tumblers around, he sounded confused. Maybe I'll just take the cylinders in and see if the shop is more capable in person than they claim to be over the phone.
Thanks for the part number info.
2001 R1100S |
I did mine a little while ago. I was able to swap the pins around, and left one out. but it is still secure enough for me. Let's face it, if someone can pick locks, one extra pin won't stop them.
Locks just keep the honest guy honest. I believe there are 6 possible pins and you can really get by if 4 of them fit the desired key.
Yea, I just swapped positions on the original tumblers and may have filed one to get it to match. I believe there are only 4 separate tumbler lengths, to worry about.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
