really dumb vibration question
When my R1200S is idling, the mirrors vibrate quite a bit - 1/4 to 1/2 inch flapping up and down. With a slight increase in RPM, the vibe instantly and completely goes away. Moving at any speed, the mirrors are rock steady.
I thought and have been told that this is "normal". Didn't like it, but accepted it. However, I just rode with two other R1200S's and neither of them had any mirror vibe at idle. All the tupperware seems tight but I'm going to have a good look today. The vibe occurs with either the stock windscreen or the Puig. I'd like to avoid a situation where the bodywork cracks in a few years (or tomorrow) due to repetitive vibration. Anybody have anything to offer on either the "normalcy" of the vibration or where I might look for a cause and solution? Thanks for your patience. Ian |
Yep, mine shake also.........it's been that way on the twins for 40 years.
Cheers |
Mine shake too at idle. As soon as I crack the throttle open a bit they are steady.
Thanks. I just didn't want to overlook an "obvious symptom" if there was something I should be doing.
Ian |
when i see my windshield vibrating more than usual, it's time for a TBS. likely the same for your mirrors.
| All times are GMT -8. The time now is 01:37 PM. |
