Ventura Bike Pack for R1200S
I have not seen Ventura racks mentioned here, they are very common in this part of the world; I have just mounted one on my R12S and found it simple to fit, well engineered and very effective. As can be seen the rack is easily removed from the support rails and an optional grab handle fitted in its place. The handle is unobtrusive and is handy when moving the bike around, the rails also provide a place to attach straps or ties if required.
The system is manufactured from steel tubing for strength but overall weight is low. The support rails mounts to the standard BMW attachment points, but since my bike has the passenger foot pegs removed I needed to add a 10mm spacer (stainless nut) to make up for the lack of the alloy peg bracket. Several bags are available, the one I have is expandable for extra capacity when required. The bag lifts of the rack, but I find it just as easy to lift the rack and bag of together. The designed load rating of the system is 9kg (20lbs). http://www.ventura-bike.com/ One up mode. ![]() Two up mode. ![]() ![]() With pack expanded. ![]() ![]() The rack. ![]() With the optinal handle mounted. ![]() ![]() ![]()
R1200GS R1200RT Aprilia RSV1000R Factory R1200S (sold) Ducati 1098S (deceased) |
R1200s mmmm!
Very nice good soloution to luggage for when you want to carry pillion to!
I have gone for a Kriega us-20 tail pack that straps on to pillion seat!
Thanks Lee ![]() R1200s Red/silver, ABS, Ohlins, Sports wheels, heated grips. K1200r - R.I.P. |
...elica rossa...
...I bought an RT...
Have a nice day ! Ron. R1200S + R1200RT |
President - Okie Chapter
___________________________ R1200s - Yellow, of course Two Wheel Oklahoma - Go watch it! |
...elica rossa...
Banned
Nice rack...
Owen,am I right when I say that the Ventura rack attaches where the rear footpeg hangers go?So Ventura rack or passenger?
Does the Ventura rack still work with the BMW factory bags? |
Banned
I guess reading your post one more time the rack works with the footpegs.
But the other question still remains... |
I have never seen the factory bags so I don’t know if the Ventura rack will be compatible sorry.
Chris
I have both the Bmw luggage, and fitted the ventura rack this weekend. It's not really compatible, but its possible. I needed to modify the mounting brackets by putting a couple of bends in each one to allow them to be mounted - sort of entwined with the BM luggage mounting bracket. It took all day, but finally worked. Its all very close fitting, but it works. It also looks like I've got the most complicated trellis frame ever produced to support the rear subframe. The ventura stuff is really quite impressive, and much stronger than I thought it would be. I'll post some piccys when i take some. Ta Chris |
Chris
Its taken nearly 2 years to get a picture, but here it is.
![]() ![]() More luggage than Paris Hilton. |
No room for pillion but I liked this set up:
2008 HP2S Sport Touring 2009 525 Beta RR North Vancouver |
Hey Peter;
Now that you have the HP2S........you can use the 12S to do two up riding. Speaking of which, how is your love life? Or should we be calling you "LeftHandPeter" once again. Oh, and when can I take the HP2S out for a day trip like you promised? Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
Whenever you like, preferrably in WA. state. It has fresh oil in the engine, tranny and FD. All ready for you. Of course we are going together and I'll be on your steed....?
WHAAAAAAAAAA? I would prefer if you just waited here and drank my beer. Cheers
Private Citizen
How do you like the fit of that wolfman tank bag on the R12s? Does it move around much?
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S (Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling." (Roger A on moderation) "Note to thin-skins and panty-bunchers - please note smiley." |
I like the fit a lot, it doesn't move around at all. Under the seat, on the pan, are two hook up points for the straps - so I can stuff them under there when not needed. Also, I stuff the front straps into the space in front of the tank and they tuck in nicely. I put 3M paint protection film at all wear/touch points (because I'm anal and black shows everything). The rear one is attached to the 4 loops that are stock and usually tucked under the rear seat. I found a low profile 1 gallon plastic gas can that fits nicely into that too.
http://www.wolfmanluggage.com/Tank/explorer_lite.html http://www.wolfmanluggage.com/Tail/peak_tail_bag.html
2008 HP2S Sport Touring 2009 525 Beta RR North Vancouver Last edited by LeftCoast Peter; 09-16-2010 at 09:46 AM.. |
Private Citizen
I like that Wolfman tail pack, I need something to carry a few odds and ends on the new R12S.
Dean O Copperhill,Tn Founder, San Jose BMW www.motorcyclistcafe.com www.sjbmwracing.com |
Hi Motosam,
Here is the GPS mount stuff - I drilled and tapped into the clip ons, mine were Heli Bars. R1200S GPS mount
