turn signal
Well I managed to break the RH rear turn signal on my new to me boxercup replica before I even got it home. Reading some posts about the stock signals it seems the OEM ones are subject to breaking. I read about people using Harley and Yamaha replacements and found a couple pics of universal type signals. Also saw some incorporated into a license plate frame. Looking for more good ideas. Not wanting to get carried away with a complete tail tidy.
I am considering these: https://www.revzilla.com/motorcycle/oxford-led-tips-turn-signal-indicators
Any experience on how easy to install the universal type are? Will these be plug and play?
Better suggestions?
I will try to get some pics and post an intro of myself and the new bike tonight.
Thanks, Ross
Old 02-08-2017, 03:55 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
It's all up to you.
Just bear in mind that with a bike such as the Boxercup Replica, as you start dumbing it down from original, what remains of the resale value will also take a corresponding hit. May not be 1:1, but that bike has a small amount of "collector" value....
But then again, lots can happen to it anyway...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 02-08-2017, 05:01 AM
Have you checked Beemer Bone Yard for used turn signals?
Turn Signals/Parts
Old 02-08-2017, 05:06 AM
AndrewM
Guest
Posts: n/a
You may just need a new post / bracket - pretty inexpensive and available from BM as they were the same across a lot of models - I'll see if I can find the part number as I bought a couple about 12mnths ago...
Old 02-08-2017, 08:52 PM
AndrewM
Guest
Posts: n/a
Part number 63132306801 Turn Indicator Holder
Old 02-08-2017, 08:57 PM
Don Ro's Avatar
AndrewM...
You're a trooper! I didn't look closely at my broken rear signal...this little gizmo separates from the signal body and is all I need and not a completely new signal.
Thanks for posting this.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 02-09-2017, 02:17 AM
AndrewM
Guest
Posts: n/a
No worries - glad to help - mine was glued on the LH side and rattled loose on a ride up to northern vic - bought 2 just in case as it's a common problem and easily broken.
All the best...
Old 02-09-2017, 07:25 PM
Gasteropod Rider
Meeni's Avatar
I have these LED turn signal:
https://www.revzilla.com/motorcycle/koso-led-turn-signals
They are not DOT legal, but they are ECE rated, which means they have some garanteed brightness and diffraction pattern.
They are bright, and work reliably.
You will need to either install an in-line resistor, or add a 1milli-ohm resistor to replace the steel bridge resistor in the flasher relay. Otherwise they'll flash too fast. If you need more input on that, I can take a picture.
Old 02-10-2017, 06:46 AM
tm1100s's Avatar
Those are obviously made of plastic but Wunderlich used to sell that part made of aluminum and virtually unbreakable. Unfortunately no longer available but maybe we can ask them to run a new batch. It's a long shot but I'd be in for 2 or 3 sets.
tm
(R12, R11, R1) + 00 then S, S, /7
Old 02-10-2017, 07:24 AM
tjs tjs is offline
I have the Wunderlich stalks . Seems like one of our machinist saavy members could make these. As easily as the plastic stalks break there ought to be a market for aluminum ones. 2cnts. from tjs
Old 02-10-2017, 02:39 PM
Thanks for the replies. I was thinking that keeping turn signals original wasn't all that important. I was hoping that with LED's the bike would be more visible. Looked into buying a replacement OEM and looks like $65, not horrible. I think I will look a little for used before I order
Old 02-10-2017, 05:12 PM
Gasteropod Rider
Meeni's Avatar
There is some value in the blinker pod breaking rather than piercing your leg in a lowside. I'm pretty sure that's the reason why all ECE compliant pods have a flexible base.
Old 02-10-2017, 07:13 PM
tm1100s's Avatar
That's a good point. The two I broke over the years, one on mine and one on the wife's, was just walking by the bikes and bumping the stalk. Snap. The aluminum pieces still pop off it you hit them hard enough, they just don't break.
tm
Old 02-11-2017, 07:26 AM
Aluminum? This is 2017. 3D printing is where it is at. ABS plastic. So far no issues. Black is OE. Blue filament was loaded in the printer so blue it was.
My Solidworks file here - https://grabcad.com/library/bmw-motorcycle-turn-signal-mount-1
-Jim
Old 02-11-2017, 06:14 PM
charlesmaillet's Avatar
Turn signal adaptors
I went the 3D printer/ABS route for new LED turn signals.
https://fortnine.ca/en/bikemaster-blade-led-turn-signals-hf-101070-10blk
I can send CAD files if anyone is interested.
Old 09-28-2017, 05:43 AM
BigDav's Avatar
Is the file already .STL?
Old 09-28-2017, 12:41 PM
BigDav,
For the OEM copy it is now. Version 2.1 (slightly larger screw hole) was just uploaded to grabcad. Both Solidworks and STL files are now included.
-Jim
Old 09-28-2017, 04:20 PM
