turboflyer's Avatar
Question 05 R1100S axial play
Did a search on axial play and way to much unrelated stuff came up. I know it was visited here not to long ago, but what is considered in limits for the rear carrier bearing axial play. I can put a dial indicator on the wheel, but if I can feel it I think it has to be to much. Have been wrong before.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 11-28-2010, 07:36 AM
My understanding is there should be none. But are you sure it's not the swingarm bearings either worn or loose? If they're snug, there's plenty of info here to loosen and retorque the FD pivot bearings.
Old 11-28-2010, 09:28 AM
turboflyer's Avatar
I will break out the manual and look at the FD pivot bearing specs. Thanks at least I am moving forward now. Hard to isolate the two no doubt.
Old 11-28-2010, 11:56 AM
The swingarm is the easiest. On the left side, remove lock nut, remove and clean the pivot pin and reinstall and retorque.
The FD is more involved but basically the same. If the pivot bearings are shot, on an 05 probably not, but if they are now would be the time to consider bronze bushings.
Old 11-28-2010, 12:03 PM
roger albert's Avatar
Or better yet, properly installed and torqued stock bearings. Done right, they hold up better than bearings. You can always snug up and paralever pivots and see if the play goes away. If not, then the final drive carrier bearing will need checking or shimming (mine became loose not too many miles after new, but has been fine since.)
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 11-28-2010, 01:15 PM
lht lht is offline
Try adjusting the left pivot pin. You have to use heat to break down the loctite. Clean it and install to proper tightness. I did mine about 2000 miles ago and it has been fine.
LT
Old 11-28-2010, 03:39 PM
Man it's flat out here!
R111S's Avatar
I put in new Para-Lever Pivot Bearings with a liberal amount of Moly Grease on the needle bearings - no problems since then. The factory put very little grease on those brearings...mine had red dust on them.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 11-29-2010, 05:35 PM
