Clutch Bleed Tool
Does anyone know what the thread pitch is on the BMW clutch bleeder tool?? I could order one and wait a week or go out in the shop and make one today.
1.00mm. tjs
Clutch bleed tool? I do not remember using any thing special on the 05 R1100S. What bike is this for? What does the tool look like. Maybe I only thought I bleed it. Fluid did seem to come out under vacuum.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
On the 11S, just open the bleed valve and remove the check valve and gravity will take over. The clutch isn't like the brakes where air is a problem. If air does get in, a ride around the block will clear any air.
