diz plaz is cwazy
RIQUE's Avatar
Air in Brake system
Howdy Folks, I decided to replace my clutch master cylinder lid that had a scuff on it. While doing so I also replaced the fluid that was pretty clean. Since the procedure was not complicated I decided to replace the brake fluid as well. While moving the master cylinder to vertical position the banjo bolt that connects the front brake hose came loose and to my dismay air got in the system
My service manual is for the early single spark with Brembo brakes. So my question is. Is the bleeding procedure the same? and what is the proper bleeding order. Thanks...and yes I will check the archives too.
The picture is of the color of the brake fluid before change. Yuk!
Life rewards action, He who is not afraid is safe!
A Zest for living requires a willingness to die!
BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny
BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo)
Old 01-16-2011, 02:41 PM
Man it's flat out here!
R111S's Avatar
I bled the brake lines on my '99 R1100S w/ABS after replacing all the lines with a Spiegle 5-Hose Braided Steel Kit. All went well but like several posted here the Front Brake line was difficult to get all the air out.
I finally used the tip of turning the Bars all the way left to set the Master Cylinder to the highest vertical location. Then pull the brake lever in and use a Ty-Strap to hold it in place. Let sit set overnight and all was better the next day.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 01-17-2011, 07:19 AM
Nitro's Avatar
I always zip-lock both the front and rear brakes (also hydraulic clutch) on my bikes when not in use, this assures air-free brake system.
Memento Audere Semper
Old 01-17-2011, 07:24 AM
diz plaz is cwazy
RIQUE's Avatar
Nitro, can you explain what zip locking is?
Old 01-17-2011, 10:44 AM
Plastic tie, big rubber band, etc.
You want to pull the lever to the grip, wrap something around the lever and grip so it holds the pressure and let it sit overnight.
Old 01-17-2011, 11:58 AM
diz plaz is cwazy
RIQUE's Avatar
Oh, I got a fancy one of those from Wunderlich. Must I leave the nipple open so that air drains?
Old 01-17-2011, 12:09 PM
Nipple on the brake caliper? NO.
With the pressure on the system caused by pulling the lever to the grip, any air in the system should rise to the brake reservoir. Not sure if this trick works on bikes with the servo braking system.
Old 01-17-2011, 12:33 PM
Do not take too seriously
throttlemeister's Avatar
More specifically, it makes the bubbles smaller (tiny) which makes it easier for them to travel up through the lines, and when you release the lever in the morning they get sucked right into the reservoir and out of the lines.
Doesn't replace proper bleeding, but can remove that last little sucker you have problems getting out.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 01-17-2011, 12:57 PM
Thanks TM. Do you know if this works on servo brakes?
Old 01-17-2011, 01:05 PM
diz plaz is cwazy
RIQUE's Avatar
I see no reason why it should not? What concerns me is that I pump the brake and the right nipple barely pours out some fluid when I open. Must I literally suck it out?
Old 01-17-2011, 01:23 PM
It does, but you need to keep in mind that with the servo brakes you have 2 brake systems: one from the lever to the ABS unit, and one from the ABS unit to your calipers. The bungie thingie on the lever is only going to do something on the first, not the second.
Old 01-17-2011, 01:36 PM
Open it a little further. If the nipple is fully open, it will squirt to the ceiling if you are not careful.
If you have servo abs, there is a very specific way of doing this. Use google, it will pop up. It is not at all like regular brakes.
Old 01-17-2011, 01:38 PM
diz plaz is cwazy
RIQUE's Avatar
TM you mean something like "bleeding ABS R1100S brakes...?"
Old 01-17-2011, 01:40 PM
I think what you want is this:
http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf
Old 01-17-2011, 01:43 PM
diz plaz is cwazy
RIQUE's Avatar
Nice....appreciate it.
Old 01-17-2011, 01:48 PM
diz plaz is cwazy
RIQUE's Avatar
I purchased a set of speed bleeders from A&S an just noticed they sent me
the wrong one! WTF!
Old 01-17-2011, 01:57 PM
