07' R1200S Ohlins question - help?
....just purchased low mileage R1200s with Ohlins suspension. I'm a short-ass, and tippie-toe to touch at a stop. Bike seems to sit high. Not being a suspension guru, is there a way to lower the suspension an inch or so? Appreciated / Brad
Old 04-22-2011, 01:18 PM
Initials & assault rifle
cageyar's Avatar
The bottom of the rear shock is adjustable.
You'll see two nuts above the bottom mount where it attaches to the swingarm.
If any threads are showing, you'll have room to adjust it and lower/shorten the shock length.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 04-22-2011, 01:44 PM
roger albert's Avatar
Barring that (i.e. if it doesn't get you enough, you can lower one or both ends, via internal shock work. If it's done along with periodic service (when you're in there changing oil anyway) then it doesn't add much to the cost.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-22-2011, 02:01 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Congrats on your purchase. As you begin to familiarize yourself with the bike read the "ohlins settings" thread. There you'll find a lot of good information regarding proper settings for the Ohlins. I had very low miles one mine when I purchased it also and had some serious handling issues that I couldn't figure out. Turned out to be the tires which had hardened while it sat around for 3 years without being riden. I spent 2 months unnecessarily adjusting my suspension due to my tire denial.
Mike
'07 R1200S
Old 04-22-2011, 02:59 PM
brent1
How does lowering the bike effect handling, lean angle, turn in? I would be happier if I could touch the ground a little more flatfooted. Thanks
Barry
2004 R1100S (Ohlins, Custom Triples, PC111, Staintune)Sold
2007 R1200S (Ohlins, Rapid Bike, Akrapocik)Sold
2006 749S Track (Many Mods)Returned to Street
2008 Sprint St (Some Mods)Sold
Old 04-22-2011, 03:03 PM
poldar12s's Avatar
You will love your 07 R12S. I would check the current tire condition like Mike mentioned first. Then, decide whether I do more freeway ridings or canyon ridings. Ohlins setting on R12S is so sensitive, per my experience. If I set for comfortable freeway cruising setup, it would not handle sharp at canyons. It's a bit rough on the freeway for me now but is perfect for canyons.
Paul from So. Cal.
07 R1200S
96 R1100RT
Old 04-22-2011, 03:22 PM
what I did was have my local sahow guy add a thicker sole to my riding boots instead of trying to lower the bike. For this worked great and cost maybe $70.
Old 04-22-2011, 03:36 PM
ohlins
Appreciate the comments - will check the current settings on the bike (previous owner was heavier), and review the ohlins setup thread...
Old 04-22-2011, 07:09 PM
akhalid40's Avatar
@oldnslow,,,,before doing anything look in the net for sag adjustment, it is very important.
r12s is a fantastic bike ..good luck,
Old 04-23-2011, 02:59 AM
Good point, and something I should have said first (and know better, but still always think to myself: "surely they've set sag before posting). If it was set up for a heavier rider (truly setup, not just owned by a big boy) then you might gain 10mm just by getting more sag into her.
Set height and sag, and if need be, go inside. it can always be handled.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-23-2011, 11:17 AM
Droptarotter's Avatar
Oldnslow;
If you have to adjust the rear shock spring preload, watch the nylon adjuster ring, they like to break.
An aluminum ring is available from an Ohlins dealer and is easy to change and not very expensive.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 04-23-2011, 11:31 AM
+1
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-23-2011, 12:00 PM
sag
..I'm going to try and review settings today, but I think you hit the 'nail on the head' with regards to sag. I'm 180 lbs., and I don't believe the bike drops any, when I sit on it - feels very hard with no give at all. I read the ohlins setup (thank you...)
Static sag should be: Rear: 10-20mm, Front: 15-30mm. Total sag: Rear: 30-40mm, Front: 28-38mm
Also review Damping Settings (and spring lengths).
Old 04-24-2011, 06:15 AM
