turboflyer's Avatar
Draining oil cooler R1100s
Just got a wild hair after 20k mile to drain the oil cooler with the service on the 05 R1100S. Not wort the hassle. Maybe an ounce. Just incase any one else was thinking about the process. I thought maybe a one way check vale was holding the oil in the cooer and lines. Apparently not.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 04-12-2011, 03:30 PM
Can't figure why you'd think that there would be a check valve in an oil cooler. Although if you put the bike on the center stand and not on the side stand when you get home, you may find that the oil quantity reads low in the sight glass.
Old 04-12-2011, 03:44 PM
turboflyer's Avatar
Seriously. If the bike was then on its left side then it would be full again, correct Check valve could have been there to prevent a drain back, similar to anti syphon in an oil filter to prevent aeration of the oil. I did not say it was in the cooler, but I suppose its possible. Maybe the thermostat would trap it there as well. At any rate seemed to drain out while servicing no need for the extra process. I think every one knows to read the sight glass with the bike level. But thanks for looking out for me.
Old 04-12-2011, 08:58 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
These bikes have 2 oil pumps and are VERY good at hiding oil.
They were trained in Munich and tested to be the best at it... they also are very good at making you think that there might be oil in the obvious places...
Enjoy the ride... don't think to much about it...
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 04-12-2011, 10:45 PM
