Centech AP2 Bus Mounting R1100S
I'm mounting a Centech AP2 Buss on my R1100S to consolidate the wiring for the Garmin Zumo, Valentine 1 Stebel Horn and outlet for heated gear. The AP2 has switched and unswitched power out options. I'm going to remove the tire repair package (I carry an air pump and tire repair kit in the system cases and tank bag. Any thoughts about the placement from you guys would be appreciated. I've installed the AP2 before on my RT; but, it had much more under seat clearance. The bus needs to stay dry and this is the best and driest place I can find on the 11S.
I took a photo of the proposed mounting position. The tire repair kit insert has been removed. http://forums.pelicanparts.com/uploa...1302647563.jpg |
I opened up the left electrical box and low and behold, there it was, a BB Power Chip set at Stage 3. There is a surprise every day with this bike. Merv, it must have been there when you bought the bike because I didn't see it entered in your pocket notebook.
Perfect
Nail - That is where I put mine. Clean installation.
| All times are GMT -8. The time now is 08:16 AM. |
