Barback King
Rapid Dog's Avatar
BMW Roundel OT - Airheads Only
...at the risk of steppin' in a pile...I need some insight, about...airhead exhausts and advantages and disadvantages.
Evidently I've exhausted all me resources, mo pun intended.
The bike in question is my '81 R100RS
So, Roger, all, let's start if I'm not boring you...
Anyone able to identify theses mufflers? Know anything about them?
Opinions? Crap? Better worse than the OEM Zuena pipes?
Better/worse mid-range or top-end?
Let's discuss.
R11S CNC BARBACKS
Old 04-18-2011, 11:39 AM
roger albert's Avatar
A yes, old Luftmeister stuff. They marketed a lot of stuff than others made, kind of like Wunderlich today. Better top end, less bottom end, want fat-ish jetting, and as much idle mixture as you can stand without the motor/plugs loading up. Even then, likely some popping on decel. Pretty nice though.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-18-2011, 11:45 AM
Barback King
Rapid Dog's Avatar
...hmmm...interesting. I was said recently by a certain someone that "If you had a healthy motor there'd be a noticable improvement in midrange over a pair of stock mufflers"
I haven't ha a stock set of OEM Zuena's on this bike yet. These Lufty's are on it now, it does have a nice midrange, nothing mind blowing.
The issue is top end. I may be expecting more than I should. It is the 1981> low compression motor.
I did a road test this week and the best it would do was 111mph per the GPS.
I'm wondering if the mufflers are suspect.
R11S CNC BARBACKS
Old 04-18-2011, 12:49 PM
Midrange seems a tad up too, but it's not like I've done hundreds of them and am an expert. I doubt that I've even done a half dozen, and of those, about half of guys don't want to lose mileage, and don't want them jetted right. 111 is not bad for an airhead. Most of them aren't as quick as most of the owners seem to remember them, anyway, maybe 115ish. I think they must have shimmed my speedo cluster wrong and have it binding up, because when it came back from speedo-repair, it was about 11 mph slower.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-18-2011, 12:54 PM
Barback King
Rapid Dog's Avatar
...seem to remember them. I concur.
All I have is a couple-three airheads to comare to this '81 for reference.
Indicated top speed on my true '77RS was 134 once. Probably 125 real.
The weird thing is this '81 won't do redline in 4th or 5th. 111 is more like <65Krpm.
Bottom line I don't want to trade these off for stockers if there's no real gain in performance, not really concerned about terminal speed.
R11S CNC BARBACKS
Old 04-18-2011, 01:25 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Something is definitely off. Have you checked your plugs for color? If it's running rich your top end will suffer but you will still have torque.
Without bags I got up to 140 according to my crappy speedo and probably could have squeezed a few more out but I got scared (the bike needs a stiffened frame). They usually read about 10 off for some reason... thus the 11 that Roger was showing is on par. So I probably hit 130ish which never seems like a real stretch without bags. That was stock with no faring. I'm guessing you have the 40mm Carbs? I can't see the mufflers robbing you that much.
Looks in much cleaner than mine!
Mike
'07 R1200S
Old 04-18-2011, 02:20 PM
Barback King
Rapid Dog's Avatar
111 per the GPS 115 per the speedo.
Nope, plugs are toasty brown, all 4 of 'em.
Here's the specs:
55K
40mm Bings, all new parts.
Complete new ignition with Motorrad Elektric Alpha bean can
Dyna coils
Newly rebuilt heads (dual pugged)
Uni foam air filter
Uses nearly zero oil
Only thing that might be 'off' at the risk of opening a can o worms, is the heads are '77-'78 squishband type but still 38mm exhaust (not 77RS)
R11S CNC BARBACKS
Old 04-18-2011, 02:33 PM
Initials & assault rifle
cageyar's Avatar
By 1981, EPA restrictions had hit all motorcycle manufacturer's selling in the U.S.
Actually 1980 was the first year of less ignition advance and neutered cam durations - I recall people complaining about it at the time.
For another example, the 1980 Honda CBX had less ignition advance and much milder cams - within a few months, you could not even buy a 1979 advance unit.
The 1980 model was a dog compared to the 1979.
Don't forget, this was time of the 85 mPH speedometers as well.
Check the specs on advance degrees and cam timing/duration/lift vs. your 1977.
I wouldn't be surprised if there were significant differences and not for the better.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 04-18-2011, 02:50 PM
Barback King
Rapid Dog's Avatar
yeah, I'm probably expecting more than I should.
Bike runs well, just a little soft. I realize it's a low-comp medel.
I also had a '91 R100GS that sported a 336 cam, it would easily out run this bike in a drag race, maybe not WFO, but close.
This has all the smog stuff removed.
The ME Alpha ignition module is designed specifically for dual plugged bikes.
so, about those mufflers...
R11S CNC BARBACKS
Old 04-18-2011, 02:57 PM
Happily Married
BumbleBeemer36's Avatar
As an owner of an '82 R100...I think you're expecting too much. Mine never quite reaches redline either. Don't know GPS'ed speed but I think it hovered right at 115 the last time I let it hang out. But it felt like it could do it all day.
And my pipes are pretty much completely open.
I have serious doubts anyone's stock r100rs ever went 130-140 mph.
It's the off-the-line that makes these bikes fun. I used to love killin Harleys in Scottsdale when I was young-er and stupid-er
Garrett Topham
1999 R1100S Mandarin/Black- Öhlins, Motolights, Hyperlites, Spieglers, Corbin, Techlusion, Ztechnik muffs, Lennie's, Hornig plate bracket. Also available: '11 Sprint GT, '10 Thruxton, '09 G650GS, '07 F800S, '06 F650GS, '03 DL1000, '98 DR350SE, '97 RMX250, '82 R100S/RS, '79 TT500, '75 CB400F, '74 TL250, '71 CT90, '69 CB450
Old 04-18-2011, 03:03 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Dual plugged too? ****.
Yeah what Cage said.... Valve clearances checked too I suppose?
Mike
'07 R1200S
Old 04-18-2011, 03:06 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Maybe I had a tail wind I can't say for certain that everything internal is stock or the old rusted pipes I had on it for that matter. It was most likely magic.
Mike
'07 R1200S
Old 04-18-2011, 03:17 PM
tm1100s's Avatar
Found this in an old Luftmeister catalog.
Luftmeister Catalog - Muffler Page
I think the Luftmeister 2 into 1 exhausts are from this company but I'm not 100% sure.
They still have some left over, though. (from 30 years ago).
MAC Exhausts
tm
(R12, R11, R1) + 00 then S, S, /7
Old 04-18-2011, 04:42 PM
tjs tjs is offline
what F/D is on your RS? 2.91, 3.00, or 3.09. I had an 83 R100 I made into an S. Stock F/D on that model was 3.09. I had the Luftmeister mufflers, 38 mm Dellorto pumpers, (stock R90S jetting) and K&N filters. I also added a CC products fork brace and had the swingarm braced. The combination of the S fairing and probably the Bar-end mirrors caused the bike to want head for tank slap territory at around 125 indicated. Very fast though in reaching that speed. Next shop I worked at I bought an 85 R80 and made it into a R1050RS. Sports Cam dual-plug,etc. Wish I had kept that one. tjs
Old 04-18-2011, 05:55 PM
Barback King
Rapid Dog's Avatar
32/11 stock rearend (2.91), valves spot on, stock jetting.
It was actually my R100/7 converted with all the 77 RS parts and an S fairing that indicated 134, tailwind, slight downgrade, barn sour for home ...
Nice find on the Luft cataloge. I've been looking for weeks for info!
R11S CNC BARBACKS
Old 04-18-2011, 06:09 PM
Man it's flat out here!
R111S's Avatar
IMO low compression is what's holding you back from reaching the top speed of the '77 Model. Unless I'm wrong the '77 had 9.5:1 Pistons right? And your newer model has 8.5:1?
Since you have Dual-Plugged Heads go for 9.5:1 Pistons and never look back.
After Dual-Plugging the Heads on my '94 R100GS/PD, I put in 9.5:1 Pistons (stock 8.5:1) and it made a big difference at all engine RPMs. It would hold redline in 5th, got better gas mileage, started better in cold temps, and low idle was very stable.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 04-22-2011, 06:29 PM
Barback King
Rapid Dog's Avatar
...actually i think its 8.2-1....low boy.
General conensus is as you say, need some hi-comp pistons.
R11S CNC BARBACKS
Old 04-22-2011, 07:58 PM
Happily Married
Talkin out my butt, but didnt the low comp motors have base gasket that could be removed as well?
Sorry, halfway through an Easter morning Peach ale.
Garrett Topham
Old 04-24-2011, 09:23 AM
Droptarotter's Avatar
Nope...........in the '80's they had done away with the base gaskets and used O-rings.
Oops........forgot about the late '70's motors did have different base gaskets.........but weren't the guys at that time adding gaskets so they could run cheaper fuel?
Remember...........the cheapest thing on a BMW is the rider!
Get back to your Peach ale!
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 04-24-2011, 09:59 AM
tm1100s's Avatar
Don't remember any engines coming with base gasket that would make a difference but there was a thicker base gasket offered to reduce compression and mitigate the valve seat problem with non-leaded fuels. Tried it, didn't like it, took it out. Never had the problem, but then again, haven't put a lot of miles on it since then (/7). I'll probably install new seats this summer just because I have the equipment available to do the job.
tm
Old 04-24-2011, 11:34 AM
