Battery tenders
Sorry if this is an oft asked question but the search function yielded zippo.
This is the first bike I've owned with a 12v accessory plug. Do you have a recommendation for an inexpensive battery tender for use with that plug? We have good riding weather much of the winter, so it won't be used too terribly much, thus the inexpensive part. |
... Beeming in BC
Your search function must have a glitch.
Having said that, the common route is to attach a fused pigtail directly to the battery with an SAE plug on the end. Then you can use just about any battery tender. Or, just get a "Battery Tender". It's bombproof, comes with a pigtail, and is reasonably cheap. $25 $50 Visit the site and decide which one works for you. CTEK units gave been reported as robust too. However, the one I looked at did not use an SAE connector. Why SAE? Because you can use it for so many things - tire inflator, power socket for charging you iPod, cell phone, etc. and so many other things. $0.02
2020 Ducati V4 (beast) 2007 R1200S (still perfect) '91 Ducati 907ie (sold - down payment contribution) '79 Kawasaki KZ1300 (sold - what a monster ![]() |
there is also the battery tender option that plugs into the BMW accessory port on the side. little more expensive but i like it for ease of use and i didnt have to run any separate wiring
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
There is a difference between using a BatteryTender on the r1100s accessory plug socket and the r1200s accessory socket. Accessory socket works fine on the r1100s just order the $5.00 accessory plug, but not well (or not at all) on the r1200s.
It's advisable to update your profile to tell people what you are riding. r1200s Accessory Socket Question - Bobby? ![]() Or, for the r1100s ![]()
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. Last edited by ckcarr; 10-15-2012 at 06:18 AM.. |
If you have a gel battery, a gel battery specific charger is recommended. These are also available from Deltran.
Battery Tender Plus - Batterytender.com |
Okay, sorry to drag up this thread again, but I didn't offer you guys all the information. I have an '04 R1100s with the 12v accessory socket. I have a trickle charger and the 12v plug attachment. No gel battery.
What's this with regard to the ignition sequence that I might need to do to get this sucker charging?
2004 R1100S |
Talk Less, Say More
But, using a basic trickle charger is different than an BatteryTender, which will cycle on and off keeping the battery at the proper charge level. A trickle charger will just run & run, with possible bad consequences, especially with a basic sulfuric acid battery. It will eventually boil all the liquid out. A good BatteryTender will set you back $20 to $35 depending on BT Jr. or regular BatteryTender.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Thank you, ckcarr.
I actually have the Battery Tender Junior. So just plug'er in and go? By the way, I'm in Moab at least three times a year. Love that little sushi joint you guys have there. Christophe
2004 R1100S |
