-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Tail light / brake light reflector removal? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/621764-tail-light-brake-light-reflector-removal.html)
JimMoore 07-28-2011 11:35 AM
Guys,
I'm installing some hyperlites on my R1100S. I need to remove the rear reflector to get at the wires behind the tail light / brake light socket. I got the cover off and the bulb out no problem, but the reflector won't come out. Is there a trick to it? I don't want to break this thing. Do I need to go in from the other (front) side?
Thanks,
Meeni 07-28-2011 11:44 AM
Please post a picture when you are done :)
Look at this diagram, there are 2 bolts that you can remove only when you have removed the tupperware plastic of the entire rear end...
http://www.maxbmwmotorcycles.com/fiche/ShowImage.aspx?image=Diagrams/B0002479.png&rnd=194538867
JimMoore 07-29-2011 01:38 AM
Thanks. I'm glad I didn't pull harder on it. I might actually be getting smarter in my old age.
Guest24 07-29-2011 04:36 AM
When working on a BMW remember Rule #1-DO NOT FORCE ANYTHING!!!
Lochinver 07-29-2011 11:28 PM
I've been looking at these hyper lights as well. If I could ask, what site and kit did you order from? was there anything special they had to/you had to do for the kit to accommodate the r1100s? Mine is a 99.
thanks
RodPlunger 11-17-2018 07:04 PM
Digging up a very old thread, but in looking at the diagram, I can't figure out where the bolts are that hold it in. Any pictures?
twitchy 11-18-2018 02:03 AM
1 - Take the rear cowl off
2 - Take the seat off
3 - Take the saddle bag mounts off if you have them
4 - Take the right and left rear side panels off
5 - Take the rear cowling around the tail light lens off
6 - Once everything is off they are easy to see.
RodPlunger 11-18-2018 11:42 AM
Cheers. Thanks...
spacewrench 01-17-2019 09:08 PM
Do you really have to take the whole back end apart to change the brake light? I took out the two screws in the red lens, but couldn't get the lens to come out. (What are you supposed to do if the brake bulb burns out while you're on the road? Sheesh!)
sgoodwin 01-18-2019 04:50 AM
You're overcomplicating it, just remove the 2 screws & pull the lens off, turn & remove bulb.
spacewrench 01-18-2019 05:36 AM
Lens is stuck somehow, I guess. You can't really grab onto it, but I used duct tape to get a hold of it, then wiggled, jiggled, twisted and pulled...no joy. I was afraid to do much more, since that lens is $60. But maybe it's just stuck to the gasket...will try again this weekend.
BadToTheBown 01-18-2019 04:39 PM
+1 There's a seal for red lens that develops some good adhesion. You only have to take the back end apart to pull the tail light reflector, not the bulb or lens....
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
