Tail light / brake light reflector removal?
Guys,
I'm installing some hyperlites on my R1100S. I need to remove the rear reflector to get at the wires behind the tail light / brake light socket. I got the cover off and the bulb out no problem, but the reflector won't come out. Is there a trick to it? I don't want to break this thing. Do I need to go in from the other (front) side?
Thanks,
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 07-28-2011, 12:35 PM
Gasteropod Rider
Meeni's Avatar
Please post a picture when you are done
Look at this diagram, there are 2 bolts that you can remove only when you have removed the tupperware plastic of the entire rear end...
http://www.maxbmwmotorcycles.com/fiche/ShowImage.aspx?image=Diagrams/B0002479.png&rnd=194538867
Old 07-28-2011, 12:44 PM
Thanks. I'm glad I didn't pull harder on it. I might actually be getting smarter in my old age.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 07-29-2011, 02:38 AM
When working on a BMW remember Rule #1-DO NOT FORCE ANYTHING!!!
Old 07-29-2011, 05:36 AM
I've been looking at these hyper lights as well. If I could ask, what site and kit did you order from? was there anything special they had to/you had to do for the kit to accommodate the r1100s? Mine is a 99.
thanks
'99 R1100S Mandarin?
"WTH is Mandarin?, Hell, that's red...er orange...yeah" - Wife
Old 07-30-2011, 12:28 AM
99 R1100S
Digging up a very old thread, but in looking at the diagram, I can't figure out where the bolts are that hold it in. Any pictures?
Old 11-17-2018, 08:04 PM
1 - Take the rear cowl off
2 - Take the seat off
3 - Take the saddle bag mounts off if you have them
4 - Take the right and left rear side panels off
5 - Take the rear cowling around the tail light lens off
6 - Once everything is off they are easy to see.
Old 11-18-2018, 03:03 AM
99 R1100S
Cheers. Thanks...
Old 11-18-2018, 12:42 PM
spacewrench's Avatar
Do you really have to take the whole back end apart to change the brake light? I took out the two screws in the red lens, but couldn't get the lens to come out. (What are you supposed to do if the brake bulb burns out while you're on the road? Sheesh!)
Old 01-17-2019, 10:08 PM
Registered Agitator
sgoodwin's Avatar
You're overcomplicating it, just remove the 2 screws & pull the lens off, turn & remove bulb.
Old 01-18-2019, 05:50 AM
Lens is stuck somehow, I guess. You can't really grab onto it, but I used duct tape to get a hold of it, then wiggled, jiggled, twisted and pulled...no joy. I was afraid to do much more, since that lens is $60. But maybe it's just stuck to the gasket...will try again this weekend.
Old 01-18-2019, 06:36 AM
+1 There's a seal for red lens that develops some good adhesion. You only have to take the back end apart to pull the tail light reflector, not the bulb or lens....
2004 R1150SR - Project Touring Bike
2005 Honda RC51 SP-2 project bike
2014 Ducati Hyperstrada - fun touring bike
Old 01-18-2019, 05:39 PM
